Oil pan drain plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2006, 05:00 PM   #1 (permalink)
View 93ToyCorolla's Photo Gallery
Oil pan drain plug
Today I was helping a friend do an oil change and when removing the drain plug it feels like it is crossthreaded. Can not take it out by hand once it is loosened. Can not screw it in by hand when putting it back on. I tighten it snug but was afraid to tighten it to torque spec. Seems OK as far as no leaks.
Is there a fix for this or does the whole pan need to be replaced. Thanks!
93ToyCorolla is offline   Reply With Quote
Old 07-08-2006, 06:16 PM   #2 (permalink)
View tech8's Photo Gallery
You may not have to replace the entire oil pan just because the drain plug is cross-threaded. The steel flange inside the oil pan, into which the threads are cut, is harder than the drain plug, which will be stripped during removal. If the pan's threads cannot be cleaned up and restored, there are drain plug repair kits available in the aftermarket.
There are oversized plugs you can buy, rethreading kits with inserts or self-tapping plugs. And there are rubber expanding plugs.
Here's are a couple of articles:
http://www.popularmechanics.com/auto...c/1272161.html
http://www.popularmechanics.com/auto...tml?page=2&c=y
Here is a site showing some oversize plugs, etc.:
http://www.cgenterprises.com/drain_p...ize_repair.htm
Oversize plugs and repair kits should be available at your local auto supply shop.
tech8 is offline   Reply With Quote
Old 07-08-2006, 06:49 PM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
well it's a 93 so I would say depends on the condition of the oil pan. If it looks all rusted and beat up I say might as well replace it before it gets a hole since now you have a reason to. If it looks nice then try his ideas. But it would depends on how much steel there is there for the threads. I would say buy one and keep it off to the side just incase this repair job goes down hill.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 07-08-2006, 07:56 PM   #4 (permalink)
Thanks Tech8 this is very helpful
Very good info!!!
Old 07-09-2006, 08:27 PM   #5 (permalink)
Question for tech8
I read on another forum that is we are dealing with a 12mm bolt the easy fix is to tap it to 1/2-20. He says there is no need to drill. Sounds like a good option since 1/2-20 are standard drain pan bolts that can be purchased. What do you think??
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
Does the Oil Pan have a gasket? NickR Tercel, Paseo, Starlet, and Sera Forum 8 06-28-2006 08:55 AM
oil change celica2004 Archived Corolla threads 13 09-09-2005 03:05 PM
How do I change the oil in a 1997 Camry joojoopoo 3rd & 4th Generation (1992–1996 & 1997–2001) 12 12-19-2004 02:08 PM
Anyone changed out an oil pan?? 89_3SFE Celica Forum 4 11-29-2004 03:59 PM
