If you were in the market for a car with good looks and performance and had money to spend, you should have purchased an older car that was more performance oriented. With the money that you will spend to do an engine swap or turbo and body kit/rims everything you could buy two or three corollas.
That being said the things you wish to do are attainable with time, research and lots of cash. It is possible to do a swap with a 2zz-ge from a Celica GT-S or Corolla XRS or Matrix XRS, but this will cost a bundle(custom motor mounts, custom axles, ECU, tranny, the engine, etc.) and in the end you still are only running 15s. It will probably be more economical for you to concentrate on handling and looks. Get rims and suspension and nice tires and then maybe make it look good. If by the time you are done with that you aren't totally jaded and still have some money then maybe get into a tranny conversion and a Turbo kit. Good luck!
