S-afce question..... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2006, 05:23 PM   #1 (permalink)
View corolla_racer's Photo Gallery
USA S-afce question.....
Can anyone help tell me if a S-afc can tune 315cc injectors for my turbo corolla...My motor is a 7afe....I'm plaining to use the 315cc injectors, so can a S-afc my tune it????Ithe injectors came out of a 7m supra....Please help....
corolla_racer is offline   Reply With Quote
Old 07-10-2006, 09:37 PM   #2 (permalink)
any help????
Old 07-11-2006, 02:31 AM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
i can tell you the safc does seem to work for some tuning..... i think i did a write up in another thread you started on how it could work on a 5-6 psi setup using double size injectors and halfing the MAP signal.....
http://www.toyotanation.com/forum/t124842.html
http://www.toyotanation.com/forum/t142399.html
Are you planning on doing this setup yourself? if so i would do some reading on EFI systems and Turbo setups this stuff is tricky to setup and without a lot of knowledge will probably end with a rod out the side of your block, melted pistons, burned up valves.....
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 07-11-2006, 10:51 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
S-AFC gives you some control over the ecu, but the limiting factors are gonna be the fuel maps. They werent designed for boost or bigger injectors. Chances are you're gonna run out of cells. S-afc isnt an ecu, its just a device used to "cheat" the ecu.
If you really want to play around with boost, get a standalone.
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
Sub/Amp question Elizle Audio, Video, and Security - Tech 5 07-13-2006 10:42 AM
Hell Question MR2Jedi Off Topic 11 07-06-2006 10:20 PM
2007 Camry Question skippy126 5th & 6th Generation (2002-2006 & 2007-2011) 5 05-24-2006 07:47 PM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
