Trany wont stay in reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2006, 07:03 PM   #1 (permalink)
View imsofilthy's Photo Gallery
Question Trany wont stay in reverse
I have a 90' Toyota Corolla with a 3 speed auto transaxle. When I shift into reverse the wheels start to move, then the trany locks up. When I press on the gas the engine trys to stall like I have the brakes applied. It does the same thing in park, instead of letting me rev up the engine it trys to stall the engine. Does anyone know what is going on and how to fix the problem? Please advise! Thanks in advance for your help!
imsofilthy is offline   Reply With Quote
Old 07-10-2006, 10:23 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Time for a new one man.. they're so cheap used that is not even worth rebuilding them.
Old 07-11-2006, 03:00 AM   #3 (permalink)
New 2006 Corolla LE owner
View ToyotaMan1281's Photo Gallery
yea time for a new car. you can get a good used one for a few grand!!
Toyota 4 life!!
ToyotaMan1281 is offline   Reply With Quote
Old 07-12-2006, 08:15 AM   #4 (permalink)
View tashirosgt's Photo Gallery
You didn't say whether you had checked the obvious things ( transmission fluid level, differential fluid level, whether the cable under the shifter console is loose).
tashirosgt is offline   Reply With Quote
Old 07-12-2006, 08:33 AM   #5 (permalink)
KDM is in
REN69's Avatar
I meant transmission, not car.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 07-12-2006, 10:08 AM   #6 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
yea even I caught he meant transmission.... then again the sedan's do go for cheap lol
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 07-12-2006, 10:28 AM   #7 (permalink)
TokyoRacer's Avatar
View TokyoRacer's Photo Gallery
Your transmisson is obviously screwed. Does your neutral gear work? My car did the same thing after repated N-Drops..apparently I ahd melted it togetehr. Reverse didn't work, the car jsut bogged...neutrakl acted as first gear..I fixed it buy driving around in neutral for awhile lol.
Kyle's 1990 Corolla SR5 - 2001 Protege ES
TokyoRacer is offline   Reply With Quote
Old 12-07-2006, 05:07 AM   #8 (permalink)
It was a bad torque converter. Replaced it, and it worked fine for over 3 months. Now its doing something similar. This time the differential leaked out the fluid and it locked up. If I rev the car really high it will move slightly, then clunk and lock up. I'm going to refill it and pray. If it doesn't work, it's back to the junkyard...
Installed some aux. reverse lights today triophan 89-95 Toyota Pickup/Hilux 0 12-27-2005 10:50 PM
5spd swapped - No reverse gear drugal Camry & Solara Lounge 7 10-10-2005 02:56 PM
Reverse threads on wheel studs? touringcamry General Discussion 5 09-10-2005 06:21 PM
Hard to move from Park to Reverse fruto123 Camry & Solara Lounge 13 07-12-2004 08:02 PM
No Reverse!! JSVH Camry & Solara Lounge 5 06-11-2004 11:24 PM
