Failed Emissons Test - HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-12-2006, 08:08 PM   #1 (permalink)
View 00CEcorolla's Photo Gallery
Hey Guys
My check engine light as has been on for a long time and a guy at Mobil mechanics shop said that it was nothing big. When I went to Jiffy Lube he said there is an incorrect fuel mixture. When I failed the emissons test it said "Too Lean"
What do you think it could be?
And how much would it cost to repair? because I'm not good mechanically at all lol
Thanks in adavance guys
00CEcorolla is offline   Reply With Quote
Old 07-12-2006, 08:36 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Someone correct me if I'm wrong, but I believe too lean usually means O2 sensor is dead, which is something Jiffy Lube doesn't work on. Either that or you need a new catalytic converter. Failing emissions usually means O2 Sensor or Cat.
Old 07-12-2006, 08:44 PM   #3 (permalink)
View lex_addict's Photo Gallery
scan the printout if u can, that way it will be easier for us to diagnose your problem.
1992 ls400
1987 corolla gt-s [coupe]
lex_addict is offline   Reply With Quote
Old 07-12-2006, 11:55 PM   #4 (permalink)
I don't have a scanner. but it says 'System too Lean (Bank 1)' Error Code P0171.
If you need any more info lemme know.
The gas cap test was fine but I failed the OBD Check.
Old 07-13-2006, 12:04 AM   #5 (permalink)
Noob :-)
View ST185's Photo Gallery
Most likely it's the O2 sensor. Check that first.
But other things can cause leaning condition.
(loose hose, dirty AFM, etc..)
93 ST185
ST185 is offline   Reply With Quote
Old 07-13-2006, 12:57 AM   #6 (permalink)
How much you think that will run me plus labor?
I'm not good mechanically.
Old 07-13-2006, 01:18 AM   #7 (permalink)
Noob :-)
If you cannot do it by yourself, buy the sensor online and have the mechanic put it on.
They are normally cheaper online.
NGK or Denso are the same quality.
For 00 Corolla 1ZZFE,
Toyota dealer $137.98
www.partznet.com 106.24 (Toyota OEM part)
http://www.sparkplugs.com/ $97 (NGK or Denso = OEM part)
ebay ~ $30 for a used one.
93 ST185
Old 07-13-2006, 02:07 AM   #8 (permalink)
Thanks alot man.
I think I'll take it to a mechanic and check it out first before I spend money.
How much do you think the labor will be?
Old 07-13-2006, 08:16 AM   #9 (permalink)
Noob :-)
1 hour or less.
93 ST185
Old 07-13-2006, 09:18 AM   #10 (permalink)
Bingo's Avatar
View Bingo's Photo Gallery
Depends on how much it is going to run you in repairs. Sometimes it is just easier and cheaper to find a shady shop that will "tweek it" and pass you.
George
Bingo is offline   Reply With Quote
Old 07-14-2006, 05:26 PM   #11 (permalink)
You asked for it...
View azcorolla's Photo Gallery
Check Engine Light is on? Take it down to Autozone and have them read the code before you spend any money. They'll do it for free. Once you have the code, then you can consider what to do.
azcorolla is offline   Reply With Quote
K&N: Why take filtercharger over drop-in filter? dELuX-4x4 2nd Generation (2005+) 88 10-02-2007 01:13 AM
Avalon and Impala score best among IIHS side crash test results for large sedans IFCAR Toyota News 1 06-24-2006 05:28 AM
Yaris failed emissions test androidGB Yaris, Vitz and Echo Forum 12 12-27-2005 12:30 AM
failed emission test nirAE86taba General Discussion 4 10-25-2003 11:28 AM
I FAILED emission! TRDragoon General Discussion 39 10-02-2003 11:17 PM
