a *horrible* sound of knocking generally reffers to a loud knocking.... ie a spun bearing/rod knock
if it's knocking from detonation then maybe whoever did the headwork (and a 3 angle valve job is pointless since that's what 4age heads have FACTORY) shaved too much and compression is way higher than it should be..... be careful, because if that's true then it probably is no longer non-interference
