loud noise comming from 4AFE head - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2006, 11:46 AM   #1 (permalink)
jdm junkie
jdm16's Avatar
View jdm16's Photo Gallery
about a month ago my engine started to make a strange sound comming from what i thought were the belts. that was part of the problem untill i sprayed them with WD40. then the noise was reduced to inside the valve cover. the noise sounds like its the valves opening and closing. its really loud. i took it to my mechanic and he told me to flush the engine and change the oil to a thicker oil. so i did that and it went away for about the first time i drove it after the oil change. but it still sounds and probably worse now. can any1 suggest anything i can do to make the noise go away?
jdm16 is offline   Reply With Quote
Old 07-13-2006, 12:57 PM   #2 (permalink)
View tashirosgt's Photo Gallery
When you speak of the noise of the valves opening and closing, no specific noise comes to mind. What is the sound like? Could it be the famous problem of "tapping" which is caused by the space between the cams and the valve depressors (or lifters) being too large?
tashirosgt is offline   Reply With Quote
Old 07-14-2006, 12:23 PM   #3 (permalink)
Gameroom cash: $201310
View ganda1f's Photo Gallery
Is the sound a little like rattling/ticking? Heard such rattle/ticking on a '94 Corolla (4AFE) before engine was warned up. Later it stayed always on. Apparently the car had 140000 km on it without the timing belt being changed. Once the timing belt was changed, the sound disappeared and the engine in general sounded a whole lot better too
ganda1f is offline   Reply With Quote
Old 07-14-2006, 04:12 PM   #4 (permalink)
jdm junkie
jdm16's Avatar
yes it sounds like rattling. the noise comes from inside the valve cover. im starting to think the engine is dieing. my gas milage is low now. honestly i hope it blows up so i can get the integra i always wanted. im tired of being underpowered lol
Old 07-14-2006, 04:27 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
..and you think an integra isnt underpowered... if my corolla was to blow, I'd get a nissan 200SX or something along those lines. NA sucks.
Old 07-16-2006, 08:18 PM   #6 (permalink)
jdm junkie
jdm16's Avatar
ofcourse the integra is underpowered, but not when u swap
Old 07-17-2006, 12:53 AM   #7 (permalink)
View 94_Rolla_Guy's Photo Gallery
theres a spring in the intake cam slave gear (under the valve cover) it automatically adjusts the gears backlash and quiets there operation if it was to stretch or break or if a cam was installed incorrectly then you can look at that otherwise check the lifter clearance.
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Loud Wind Noise Solved! EngineerBoo 2nd Generation (2005+) 17 11-30-2008 11:21 AM
Question about head repair for a 4afe $modelman$ Celica Forum 3 05-26-2005 02:16 PM
Loud clanking noise and Jerking. HELP!! stiltz Camry & Solara Lounge 7 11-17-2004 07:15 PM
loud squeaking noise from inside car CanadaGTS Archived Corolla threads 11 02-18-2003 10:27 AM
