O2 Sensor replaced - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-14-2006, 11:14 AM   #1 (permalink)
View czvig's Photo Gallery
O2 Sensor replaced
The check engine light came on in my 1997 Toyota corolla. I took the car to Advance to get the codes read. The codes were P0136, Circuit malfunction (bank 1 Sensor 2). The salesperson said it was the front sensor (before converter). I bought it and replaced old one. Now the light is still on.
Will the light turn off on it's own?
Did he sell me the right sensor?
Do I need to disconnect the battery for 15 mins to reset computer?
czvig is offline   Reply With Quote
Old 07-14-2006, 12:31 PM   #2 (permalink)
View 00CEcorolla's Photo Gallery
i'm not exactly sure but sometimes they just need to swtich it off...i've heard that alot of hondas and toyotas have 'check engine' light problems meaning they stay on even if the car is fine.
00CEcorolla is offline   Reply With Quote
Old 07-14-2006, 08:44 PM   #3 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
you need to reset your computer, usually if you just disconnect the negative terminal of the battery for about 30 mins it will turn itself off.
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 07-17-2006, 08:30 AM   #4 (permalink)
Thanks, I have driven 100+ miles and it seems to have done the trick.
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Error code 21 O2 heated Oxygen Sensor failure pkmorreira 89-95 Toyota Pickup/Hilux 11 02-05-2011 03:02 PM
2000 Echo - O2 sensor failure Ashla Yaris, Vitz and Echo Forum 4 03-15-2006 03:48 PM
O2 sensor problem fox_prime Camry & Solara Lounge 2 09-09-2005 12:42 AM
