17" Rims on 89 Rolla GT-S - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-14-2006, 12:09 PM   #1 (permalink)
csn
View csn's Photo Gallery
AE92 17" Rims on 89 Rolla GT-S
Do you think 17" rims w/ 215/45/R17 tires will fit on my 92?????
~Chris
Newbies learn the hardway!!!!!
csn is offline   Reply With Quote
Old 07-14-2006, 12:20 PM   #2 (permalink)
View RA24_4_Me's Photo Gallery
I think that is way too big for an AE92. I cant stomach anything bigger then 16's, and I will be running 15's on my car.
RA24_4_Me is offline   Reply With Quote
Old 07-14-2006, 12:44 PM   #3 (permalink)
View anthony9789's Photo Gallery
i don't think it will fit because i had a set of 17s with 215/45/17 and it rubbed on my integra 94....i am looking for rims for my ae 92 and what i want is 15 , or if i get 16 for a good price..
www.cardomain.com/ride/2403591
anthony9789 is offline   Reply With Quote
Old 07-14-2006, 12:54 PM   #4 (permalink)
iya_ke35's Avatar
View iya_ke35's Photo Gallery
It will not fit.. try going for a 15x8 deepdish old school enkies.. best looking fo an AE92..
iya_ke35 is offline   Reply With Quote
Old 07-14-2006, 12:56 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
with my 16x7 rims with a 42 mm offset and a 205/45 tire on it JUST fits. ANy bigger and it would rub the rear suspension. so there is no way with that tire that those will fit your car
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 07-14-2006, 12:57 PM   #6 (permalink)
csn
Enkei rims are nice, but I got a good deal out of the 17's. I'mma resell them and get some different ones. I put one up next to my car and they are way to big. But I can double my money on these more than likely.
~Chris
Old 07-14-2006, 02:03 PM   #7 (permalink)
iya_ke35's Avatar
why dont you just stick with that OEM rims you got, those are called Levin Rims in Japan.. drop the car and change the tire size.. I did it to my AE92.. check it out below..
Old 07-14-2006, 02:05 PM   #8 (permalink)
csn
No offense but i really don't care for the rims to much... I also do alot of interstate travel so I like my smooth ride. Oneday when I get another daily I might drop it and do some other stuff but right now just want it to look good.
~Chris
Old 07-14-2006, 03:41 PM   #9 (permalink)
Vroom?
freakinbox's Avatar
umm they aren't just for the levin...
BUt yea you can get 17's on the car but you will have almost no tire. I wouldn't go less than the sidewall I have now. It's saved me on a few pot holes i DIDN'T SEE ....
they have to have a pretty decent offest too. And with mine the rim doesn't rub but the rim protector on the tire did.
Old 07-14-2006, 06:07 PM   #10 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
What offset would you suggest for a set of 15x8s??? and what tire size??? I'm assuming spacers "might" be needed.
BTW you can install 17s on an AE92 but you need to have:
A. The right offset of wheels (38-40mm 42mm max depending on wheel width)
B. The right tire size (205/40-17 max, 205/45-17s might fit but you might rub when you hit road bumps)
You may also need spacers, in which case depending on how thick the spacers are, you might need longer wheel studs from Toyota.
17s are overkill dude, you will feel everything on the road and your ride comfort will be non-existant. 16s should be the max on an AE92 (205/40-16 or 205/45-16).
Old 07-14-2006, 06:42 PM   #11 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
View Kr0n1k's Photo Gallery
These are nice, I know they are usually on Honda's but they would like damn nice on an AE92.
Kr0n1k is offline   Reply With Quote
Old 07-14-2006, 06:43 PM   #12 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
http://cgi.ebay.com/ebaymotors/Brand...07536737QQrdZ1
sorry double post link didnt work.
Old 07-14-2006, 11:02 PM   #13 (permalink)
Vroom?
freakinbox's Avatar
like I said, 205/45-16 on my car and it's so close to the plate fot the spring in the rear that it clears the dirt off that area... and even with a 42 offset on mine it still rubbed the rim protector off on the inside of the rears..
Old 07-15-2006, 09:42 PM   #14 (permalink)
View lex_addict's Photo Gallery
^ +42 offset is too high for ur application, since ur getting rubbing...maybe try a spacer to bring the offset into the 30's, that should alleviate ur rubbing issues...or maybe try a 195 width tire for that hippari look
1992 ls400
1987 corolla gt-s [coupe]
lex_addict is offline   Reply With Quote
Old 07-15-2006, 09:52 PM   #15 (permalink)
KDM is in
REN69's Avatar
kron1k, those are Rota Slipstreams which are copies of MUGEN rims.. hence the reason why they're always on Hondas.. MUGEN = HONDA TUNER.. Leave the Honda stuff for the Honda dudes.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
