'94 Prizm eats oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2006, 02:33 PM   #1 (permalink)
Blue Scapegoat's Avatar
View Blue Scapegoat's Photo Gallery
Question '94 Prizm eats oil
My dad has a '94 Prizm TSi with the 4A-FE engine, and it eats oil like crazy. He says it smokes when he goes heavy on the gas, and he always carries a box of oil in his trunk so he won't run out. I was told in the Celica forum that my '92 celica smoking a little on start up could be caused by an old Exhaust Valve seal. Is it possible that this is the same problem afflicting the Prizm?
Thanks
Blue Scapegoat is offline   Reply With Quote
Old 07-21-2006, 10:06 PM   #2 (permalink)
View tashirosgt's Photo Gallery
I suggest doing a compression test to rule out a major engine problem. If the compression is OK then look for the little stuff.
tashirosgt is offline   Reply With Quote
Old 07-21-2006, 11:21 PM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
7A-FE's are notorious for bad piston rings... 4A's can have similar problems but usually go quite a bit longer 200k + before problems...
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 07-22-2006, 09:34 AM   #4 (permalink)
View Turk_Rolla's Photo Gallery
I have the SAME problem in my 98 corolla le, i bought a used engine from a 99 prizm.
I believe its just a head gasket. replace that and your problem MIGHT be solved.
Turk_Rolla is offline   Reply With Quote
Old 07-22-2006, 10:42 PM   #5 (permalink)
98-99's although less common are also known for bad piston rings
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Trading Taco for a moped big chris 2nd Generation (2005+) 126 04-22-2006 04:04 PM
98 Prizm oil consumption / compression results stubborn1 Archived Corolla threads 12 04-10-2006 04:36 PM
Need very hot temperature motor oil suggestions. Blek General Discussion 20 07-15-2004 09:59 PM
impending suspension install '94 Geo Prizm and ME/MINE/MODS gszczyrb Archived Corolla threads 3 08-01-2002 12:13 AM
