taking off crankshaft pully - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2006, 03:21 PM   #1 (permalink)
View gregm's Photo Gallery
Hi -- I am removing a timing belt from a 1995 Corolla. The Haynes book said to stick a wedge into the transmission (automatic) flywheel so I can take out the bolt, but I removed the plastic cover but still cannot wedge the flywheel. Any other ideas of how I can remove the crankshaft pulley bolt?
gregm is offline   Reply With Quote
Old 07-23-2006, 03:30 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
I removed it by putting a bolt in the crankwheel (theres places there for the toyota sst) flatbar and then just brute force.
Old 07-23-2006, 07:10 PM   #3 (permalink)
crankwheel holes?
Thanks for the tip. I cannot find any holes in the crankshaft pulley or any way to hold it down. Perhaps the engines are different in this regard? Any additional insight will be appreciated.
Old 07-23-2006, 07:38 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
Why can't you jam the ring gear?
I just pushed the end of my prybar into it then undid the bolt, it should be easy.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 07-23-2006, 09:52 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
if your having that much trouble with it they do make special pullers for this kind of crap...
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 07-23-2006, 10:45 PM   #6 (permalink)
View tashirosgt's Photo Gallery
I think the simplest way to get the crankshaft pulley bolt off is to use an impact wrench. I avoid using impact wrenches, but this is one case where it is the simplest way. You don't need an elaborate arrangement to hold the pulley. A very slight force will hold it enough for the wrench to work. ( Another place where the impact wrench comes in handy is removing alternator pulleys.)
tashirosgt is offline   Reply With Quote
Old 07-23-2006, 10:49 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
I used an impact gun when we did the timing belt on a ford escort
Old 07-23-2006, 11:58 PM   #8 (permalink)
The TN Member
Another crude method is to use the starter motor to undo it, but thats probably a bad sugestion to make.
Old 07-25-2006, 09:10 AM   #9 (permalink)
Impact wrench was the way to go
Thanks to all who offered advice. A friend had an impact wrench, and it worked to get off the crankshaft bolt without any problems. Now for my fun part -- determining if a water leak is a gasket, head, or engine block problem.
Tensioner Pully -MKI Red October MR2 Forum 0 07-17-2006 12:29 AM
Crankshaft pulley trouble... BIG BIG TROUBLE!! and little bit of reading... _VVTi_ Camry & Solara Lounge 12 06-18-2005 10:20 PM
Best way to remove crankshaft pulley nut (flywheel inspection cover?)? awmccready Camry & Solara Lounge 5 11-26-2004 12:58 PM
Crankshaft pully bolt '99 V6 mikebourg Camry & Solara Lounge 11 11-15-2004 12:04 PM
under drive pully... BLUEMEANIE Hardcore Tech and Competition 2 10-17-2003 11:44 AM
