86 Corolla 3-speed automatic leaks above pan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2006, 11:25 PM   #1 (permalink)
View larrymoencurly's Photo Gallery
I have a 1986 with the A131L automatic, which suddenly started leaking about a tablespoon a day, and the leak doesn't seem to be from the pan but higher up. I'm having trouble pinpointing the leak because the fluid is spread all over. Shifting feels just as it always has.
Where is the likely source of the leak?
larrymoencurly is offline   Reply With Quote
Old 07-24-2006, 09:15 AM   #2 (permalink)
View tashirosgt's Photo Gallery
One thought is that the fluid is from where the axles go into the differential.
tashirosgt is offline   Reply With Quote
Old 07-24-2006, 09:32 AM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Degrease the engine from about half-way up to the pan. Go for a drive then see where its coming from... Should be able to pinpoint it better from there...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 07-24-2006, 06:34 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Chances are its the valve cover seals, 20yr old seals are probably ready to replace.
Old 07-24-2006, 08:31 PM   #5 (permalink)
Is that the transmission pan gasket? Because it does cover the valve body, and the leak is definitely red Dexron and not engine oil. Worse...
...I discovered that the leak isn't from the differential but is probably the transmission input shaft seal. Is there a relatively easy way to separate the engine from the transmission?
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 02:12 AM
Please HELP!!!! 86 Corolla will not idle smoothly!!!!!! St/\\\nfeld Archived Corolla threads 8 05-26-2004 09:30 PM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 10:54 AM
