It will fit, but it will probably be cheaper and easier to get the whole engine. For one, the Compression ratio on a 20v ST it 10.5:1 and BT is 11:1. Depending on the gen of the block, it is around 8:1 on a 16v.
The second problem is the conversion from MAP to AFM in the ST. The third is the ECU. The 16v ECU will not run the 20v Head. The fourth then comes with the wiring. The 20v head and ECU will need the 20v Wiring Loom. The next issue is fairly simple: the 20v has a knock sensor on the back of the block, the GE's and FE's (unless it is a 7A, or a GZE) dont have one, so this is also a problem as the 'safe' fuel map on the 20v sucks.
So in other words, unless you are building a 7A-GE 20v Hybrid, get yourself a complete engine and wiring loom... Will be much easier...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
