oil temperature gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2006, 07:49 PM   #1 (permalink)
View wkucardinal's Photo Gallery
My engine temp gauge seems to fluctuate constantly in the 50% range between hot and cold. Sometimes it will get up toward hot, then 5 seconds later it will drop below mid range, then it will be in the middle. This doesn't necessarily correspond to the cars performance. Sometimes I see all of these behaviors while cruising at the same constant speed of 60 mph. It's not overheating. What's causing this? COuld it be low on antifreeze? (I haven't checked yet.)
I Just got the car not long ago, and my mechanic lost some antifreeze when inspecting the alternator. I topped the coolant off with prestone 50/50 premix. Could this be cuasing the problem? That stuff is supposed to mix with any color/any mix.
-B
wkucardinal is offline   Reply With Quote
Old 07-25-2006, 02:20 AM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
faulty temp sensor?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 07-25-2006, 02:47 AM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
I remember one of my cars doing that when the thermostat starts to fail.. once it fails it's either stuck open or closed.
Old 07-25-2006, 03:21 AM   #4 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
It may have been topped off but what you are describing is a typical symtom of low antifreeze.
Wait till the car cools and check the level, you may have to top it off some more.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 07-25-2006, 11:07 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
you might have air in the system.
Old 07-25-2006, 11:55 AM   #6 (permalink)
Vroom?
freakinbox's Avatar
I would also like to point out since I noticed the title, it's not your oil temp it reads the temp of the coolant.
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 02:17 PM
Oil filter relocation warning! jeffmazz 1st Generation (1995.5–2004) 12 02-19-2009 02:24 PM
Oil pressure gauge saiklon Archived Corolla threads 7 04-02-2005 01:54 PM
hooking up autometer gauge jerryb78 Cressida Forum 2 03-20-2005 10:57 AM
