oil temperature gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2006, 08:44 PM   #1 (permalink)
View wkucardinal's Photo Gallery
My engine temp gauge seems to fluctuate constantly in the 50% range between hot and cold. Sometimes it will get up toward hot, then 5 seconds later it will drop below mid range, then it will be in the middle. This doesn't necessarily correspond to the cars performance. Sometimes I see all of these behaviors while cruising at the same constant speed of 60 mph. It's not overheating. What's causing this? COuld it be low on antifreeze? (I haven't checked yet.)
I Just got the car not long ago, and my mechanic lost some antifreeze when inspecting the alternator. I topped the coolant off with prestone 50/50 premix. Could this be cuasing the problem? That stuff is supposed to mix with any color/any mix.
-B
EDIT: title is supposed to say engine temp gauge.
wkucardinal is offline   Reply With Quote
Old 07-24-2006, 11:10 PM   #2 (permalink)
corrected the problem. low antifreeze. the reservoir showed full but after looking into the radiator i needed to add quite a bit.
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 02:17 PM
Oil filter relocation warning! jeffmazz 1st Generation (1995.5–2004) 12 02-19-2009 02:24 PM
Oil pressure gauge saiklon Archived Corolla threads 7 04-02-2005 01:54 PM
hooking up autometer gauge jerryb78 Cressida Forum 2 03-20-2005 10:57 AM
