side mirror replacement help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2006, 06:32 PM   #1 (permalink)
View spikeit's Photo Gallery
I need help in replacing my driver side mirror on my 1990 corolla sedan. Have never replaced a mirror, but I am handy enouh -- have installed CD and fog lights. Any help is appreciated.
spikeit is offline   Reply With Quote
Old 07-25-2006, 08:17 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Manual or power?
If manual, unscrew the lever, pull it, pop the inside cover, undo three more bolts, pull, install new mirror, put things together in reverse.
If power, you may need to remove the inner trims to get at the power mirror connector. Then pop the cover and go as above. Remember to plug the mirror in before reinstalling the inner door panels.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 07-25-2006, 08:41 PM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Power mirror plugs are inside the door trim... but it is as simpla as popping off the inner triangular bit off the door, then undoing the three bolts and your done...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 07-26-2006, 08:50 PM   #4 (permalink)
Thanks Buurin. Very much appreciate your help. Will do it this weekend.
Old 07-28-2006, 11:44 PM   #5 (permalink)
Buurin, thespud,
Replaced the mirror earlier today. Thank you for your help. Your instructions were clear and precise.
F/S 2000 Toyota Camry *damaged* *repairable* Only 63k!!! 92SayOh Vehicles 8 12-16-2006 05:56 AM
Avalon and Impala score best among IIHS side crash test results for large sedans IFCAR Toyota News 1 06-24-2006 05:28 AM
Aftermarket alarm installation ?... Crowleys Camry Audio, Video, and Security - Tech 5 03-17-2005 06:10 AM
Passenger side window stopped working 92MR2 MR2 Forum 2 12-04-2003 02:36 PM
