1993 Wagon Tranny Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2006, 10:25 PM   #1 (permalink)
View JeepsterJay's Photo Gallery
I have a 1993 Corolla Wagon, 1.8l, Auto, 290k on the car.
Here is the problem I am having, the tranny doesn't seem to shift out of second gear. I drove the car home when I bought back in December and it worked fine then.
I just finished all the work that needed to be done on it and put it on the road and am now having this tranny problem.
JeepsterJay is offline   Reply With Quote
Old 07-26-2006, 11:27 PM   #2 (permalink)
View toyomoho's Photo Gallery
There are shift valves, etc. that can go bad, get plugged. You might try changing the trans oil (if you have not yet done so) and see if this helps. If electronic control, you might check for loose wires. 290K miles is a lot for a transmission. A good used one may be pretty reasonable.
Old 07-27-2006, 02:11 AM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
290k kms actually since he's from Canada, chances are the transmission wasn't treated properly, change the transmission fluid and if this doesn't work; you might just need a new one.
Old 08-14-2006, 12:41 AM   #4 (permalink)
Just an FYI, it ended up being the Neutral Safety Switch.
!!new 5SFE tranny needed!!! streetnasty Celica Forum 3 09-03-2006 08:46 PM
91 Camry wagon transmission question behindbars1544 1st & 2nd Generation (1983–1986 & 1987-1991) 4 11-18-2005 07:20 PM
FS: 1993 Toyota Corolla - Sedan and Wagon Astroboy Vehicles 1 10-14-2004 10:35 AM
