cv shaft how to tell if bad on 91 rolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2006, 12:55 AM   #1 (permalink)
View kongmen's Photo Gallery
What do I look for when trying to determine if the cv shafts are bad? Thanks.
kongmen is offline   Reply With Quote
Old 07-26-2006, 01:59 AM   #2 (permalink)
View toyomoho's Photo Gallery
A failing half shaft joint will often make a clicking noise when turning. The bad joint is usually on the opposite side of the direction of the turn. The joint can also make a clunk when the transmission is engaged. Cause vibration when driven at higher speeds. Most often it is the clicking noise that provides the most notable clue.
Old 07-26-2006, 02:13 AM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
CV's will Clunk generally when turning.
Visual inspections generally are any cracking or taring in the boot, as well as the loss of the boot entirely (I have seen this once ) or a loose boot causing loss of grease
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 07-26-2006, 03:02 AM   #4 (permalink)
Thanks.
Old 07-26-2006, 03:33 AM   #5 (permalink)
Dave's
Gameroom cash: $123850
View Dave's's Photo Gallery
Mine didn't click but you could grab the shaft and move it around.
Dave's is online now   Reply With Quote
Old 07-26-2006, 06:29 AM   #6 (permalink)
View cashcrazy's Photo Gallery
Drive the car on some ramps, crawl under the car, and twist the cv shaft. If there is a bunch of slack then you have a bad cv-shaft.
cashcrazy is offline   Reply With Quote
1991 Camry Knocking R Front...Bad CV? jefe 1st & 2nd Generation (1983–1986 & 1987-1991) 2 11-06-2004 01:49 PM
84 rolla Spirit? good or bad? MalooMAN Archived Corolla threads 0 09-05-2003 05:31 AM
