1986 Corolla gets GROSS POLUTER - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2006, 11:52 AM   #1 (permalink)
View makoona's Photo Gallery
I'm trying to get my corolla to pass CA emissions... keeps coming up gross poluter running very rich. i'll post the numbers here later today. the carb guy says all the enrichment diaphrams and the float are fine. any ideas on how to get this motor running clean?
makoona is offline   Reply With Quote
Old 07-28-2006, 01:55 PM   #2 (permalink)
View toyomoho's Photo Gallery
HC is unburned oil and gas in vapor form. A common cause of high HC is ignition misfiring. Fouled plug(s), bad plug wire(s), too lean or rich idle adjustment, vacuum leak, low compression, and bad exhaust valve(s). Sometimes replacing a single bad plug makes all the difference. Oil burning is caused be worn guides, rings, cylinders, bad PCV.
A high engine HC will be hard on the catalytic converter due to higher working temps. A three-way converter that is failing or has failed will cause a higher HC.
Check anything that would affect engine performance. Things such as timing, choke failing to completely open, dirty air filter, engine coolant not a normal operating temp. Having clean oil will lower HC emissions a little. Make sure the engine is warm when tested.
I thought there were autoshops that could test your emissions before the official test.
Old 07-28-2006, 06:30 PM   #3 (permalink)
first test at garage:
15mph HC max152 measured 231 co max 91 measured 3.82
35mph 127 259 .71 3.92
then i replaced plugs and air filter, oil, added techron and marvel oil to gas, and restore and marvel oil to crankcase oil. retested at test only facility on dyno and got this:
15 mph 298 4.88
25mph 209 2.17
then tested compression and got 190 on all cylinders, but found a bunch of vacume lines burned through. (carb guy didn't spot these... hmmm.. ) have replaced vacuum lines and might set timing if i can find a light. btw, car only has 44k on it. going to test again since fixing vacuum lines and will report back. thanks for good info.
Old 07-28-2006, 08:36 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Time to get out of California dude.
Old 07-28-2006, 09:10 PM   #5 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
View Kr0n1k's Photo Gallery
Yea no kidding, as long as your car isn't a 96 or newer in NY, they don't check much of anything for insepction. I passed with holes in my exhaust, no speedo, a gas leak, all sorts of crap wrong with the car. All they checked was lights, mirrors, tires, and brakes. Also made sure I didn't have cracks in my glass. Never even popped the hood.
Kr0n1k is offline   Reply With Quote
Old 07-29-2006, 10:03 AM   #6 (permalink)
Originally Posted by Kr0n1k
. I passed with holes in my exhaust, no speedo, a gas leak, all sorts of crap wrong with the car. .
Damn, that sounds like a sweet ride!
Old 07-30-2006, 10:56 AM   #7 (permalink)
Sexy Run
AE92_GTS88's Avatar
View AE92_GTS88's Photo Gallery
same here i also got that with my 85 rolla, cali smog sucks, mine isnt even a real smog, i have to get a test smog or some crap like that.
AE92_GTS88 is offline   Reply With Quote
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
FS - 1986 Toyota Corolla GTS Coupe Takeshi_Nakazato Vehicles 30 09-28-2006 06:57 AM
Questioning the 2006 Corolla again...... RAV4EVR Toyota News 16 08-01-2005 12:26 PM
1986 corolla ae86 1985rollasr5 Vehicles 8 07-29-2005 02:41 PM
1986 Corolla hesitates when coasting in gear LurkinHomer Hardcore Tech and Competition 4 02-16-2004 04:12 PM
