Help!! 91 toyota won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2006, 07:52 PM   #1 (permalink)
View ExoticKiss's Photo Gallery
Question Help!! 91 toyota won't start
One day we were just driving along and the car just suddenly turned off. It will turn over but it just won't spark!! We've changed the distributor, we've checked the timing belt, we've changed the ECU and the fuel pump does kick on when you try to start it so we know it's not that. Right now we're in the process of checking sensors and checking for faulty wires.
What other posibilities are there??
It's a 1991 Toyota Corolla DX 1.6 liter A4FE if that helps.
We really have know idea what else to try
Any suggestions would be greatly appreciated!!
Thanks,
Jessi
ExoticKiss is offline   Reply With Quote
Old 07-29-2006, 09:13 PM   #2 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
Pull the distributor cap off and turn it over.
If the rotor does not go round and round ... broken timing chain/belt.
Otherwise I'dd look for a bad ground or faulty igniter.
but .. those are just guesses.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 07-29-2006, 10:28 PM   #3 (permalink)
View tashirosgt's Photo Gallery
Are you getting any battery voltage at the distributor?
tashirosgt is offline   Reply With Quote
Old 07-30-2006, 11:42 AM   #4 (permalink)
We've checked the timing belt and half the distributor is getting power and half of it's not. But, the only wire that doesn't light the tester up turns the fuel pump on. We're coming to the conclusion that it's the MAP sensor. Would that cause the car not to start? All I know is that the MAP sensor has to do with fuel delivery and ignition timing.
And I'm pretty sure my dad checked the ignitor before he had it towed back here but I'll have to recheck on that.
Old 07-30-2006, 11:46 AM   #5 (permalink)
Ok disreguard what I said about the distribtor. I was just told that all the distributor is getting the power it needs now.
Old 07-30-2006, 04:44 PM   #6 (permalink)
These are the components of the "Electronic Control System" of the 4AFE according to the terminology of the Service Manual:
Oxygen Sensor (Under the car at the end of the exhaust manifold)
Start Injector Time Switch (front driver's side of block, under distributor and between two hoses)
ISC Valve (passenger's side of throttle body-intake manifold assembly)
Vacuum Sensor (In engine compartment, top center of firewall)
Water Temp. Sensor
Check Connector (In engine compartment on driver's side near body around strut mount )
Intake Air Temp. Sensor (Plugs into the black plastic box that holds the air filter)
EFI Main relay (In the black plastic fuse box on the drivers side of engine compartment)
ECU (the computer, inside he car, at the bottom of the center console below cup holde, ash tray and that stuff)
Circuit open relay ( near the ECU, more toward the rear of the car )
Old 07-30-2006, 07:51 PM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Have you guys checked the ignitor?? (not sure if the 4AFE has one, but I assume it would)
Old 07-30-2006, 07:59 PM   #8 (permalink)
View Kiwi turbo's Photo Gallery
Check your ignition leads and get an autoelectrtion to check your regulator replaceing your spark plugs is also an option.
Kiwi turbo is offline   Reply With Quote
Old 07-30-2006, 08:57 PM   #9 (permalink)
We've tried everything above lol. The spark plugs are brand new too. We're having a mechanic come over to look at sometime soon and if he can't figure out then it's going to the junk yard. I hate to but i can't put any more money into this car. it only has 123k miles on it. I flipped it 2 years ago and i've put so much money into it already but I'm thinkin it's going to end up in the junk yard
thanks for all the suggestions though!!
-Jessi
Old 07-31-2006, 02:00 AM   #10 (permalink)
KDM is in
REN69's Avatar
What about the fuel pump? didn't notice that on your list.
Maybe the motor is dead.. time for a new one.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 07-31-2006, 09:49 AM   #11 (permalink)
The fuel pump is mentioned in the first post. It kicks on when we try to start the car and we can smell the gas. And we found the fuel pump wire and when we tested the wire the fuel pump would turn on so we're sure it's not that
Toyota's Dyin out Valentino Celica Forum 16 07-23-2007 11:36 PM
Toyota and Nevada Partners Team Up 02AspenGreen Toyota News 0 04-13-2006 08:41 PM
Starter Contact Kit Question. slbks5 89-95 Toyota Pickup/Hilux 6 01-26-2006 06:40 PM
83 Toyota Tercel will not cold start with key, but will push start?! OgdenRob General Discussion 5 02-18-2005 12:03 PM
