'01 corolla hep pls. TIA - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2006, 01:58 PM   #1 (permalink)
View aldouse's Photo Gallery
Exclamation '01 corolla hep pls. TIA
and so the question is, my gf's '01 corolla S has an electrical issue. the ignition doesn't crank. you turn the key and it makes repetitive "clicking" noises. and it doesnt even turn over. i know it can't be the battery as it was just recently changed a few months back and besides it still powers up the radio and headlights fine.
so what do you guys think just based off this info. the starter? the whole ignition system? i'd figure i'd ask the community before i take it to a money sucking dealership/tech center that'll tell me i need to replace everything.
TIA
aldouse is offline   Reply With Quote
Old 07-30-2006, 04:54 PM   #2 (permalink)
View tashirosgt's Photo Gallery
If your alternator isn't charging, it could be the battery even though you just changed it. Sometimes a battery is strong enough to run the lights and radio but won't crank. A simple thing to try is to clean your battery terminals.
A bad starter is also a possibility. Some modern cars have computers that won't let the engine run if they sense certain faults, but I suspect your 2001 isn't that clever.
tashirosgt is offline   Reply With Quote
Old 07-30-2006, 05:12 PM   #3 (permalink)
View petec's Photo Gallery
Probably the starter.
petec is offline   Reply With Quote
Old 07-30-2006, 07:46 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Check the alternator, starter and battery as either one could be the culprit.
Old 07-30-2006, 09:33 PM   #5 (permalink)
thank you all for your kind words and advice.
well... i tried my optima red top from my subby into the corolla and alas still no start. so i'll have to say its safe to assume that i'm going to need a new starter.
so my next question goes... any particular dealer/service station or autoshop in the san jose, california area do you guys highly recommend?
again thanks all for your much needed help and support. TIA!
Old 07-30-2006, 09:50 PM   #6 (permalink)
View thkey19's Photo Gallery
I am willing to bet it is the "contact points" on your starter. The kit is about $6 for each terminal. one for the positive and one for the negative. Here are some links that will take you to some pics, in case you want to DIY. GOOD LUCK!
TK
Repair your own STARTER
http://www.automotiveforums.com/vbulletin/t424063.html scroll down to the third or fourth post for MANY links!
Here is a place you can get the parts:
http://oem.thepartsbin.com/parts/the...20Set&dp=false
I bet the positive side is the culprit. Sometimes the ground side is HARD to find! Good Luck
thkey19 is offline   Reply With Quote
Old 07-31-2006, 01:30 AM   #7 (permalink)
JZ TWINS's Avatar
View JZ TWINS's Photo Gallery
I agree. Check the starter contacts
JZ TWINS is offline   Reply With Quote
185/65/14 01 Corolla Tires chocowallet Archived Corolla threads 1 07-16-2006 02:34 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
01 & 02 Corolla factory alloy wheels & TRD 16" ata3001 Archived Corolla threads 5 01-02-2003 10:53 PM
NEW Body Kit for 01 ~ 02 corolla hooolala Archived Corolla threads 1 10-31-2002 09:41 AM
01 Celica GT-S owner going to 03 Corolla S --- has questions TonyFl Archived Corolla threads 3 09-23-2002 11:34 PM
