^we dont have hatches here in the US :p
loomdog, its easy mang, the front turn signal lights are easy as heck! just unscrew that one bolt and it should just come right off when you mess with it, if it doesn't, just go from under the bumper and push it out, thats what i did
as for the rear lights, those are freakin easy as heck too! open your turnk, on one side there are two screws that you can visibly see, then there is just one more that is directly behind the lights, you need to take off the carpet linings on the trunk to see it, there are a couple snap-ons you will need to take off, and open the linings up and voila! you will see a little screw that's holding the rear lights, take that off and if it doesn't pop right off and PUSH that thing off with force! mwahahhahahaa.....
