MAF Sensor Compatibility Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2006, 06:38 PM   #1 (permalink)
View SubieHo's Photo Gallery
Hello All,
My dad's 2001 Corolla just threw a code P0171 (fuel trim lean bank 1). From what I've read, it's probably the MAF sensor. I think the O2 sensor is fine because the car has only 21K miles on the odm. I just have a couple of quick question:
Is there a way to test MAF sensors (with a voltmeter)?
Would an O2 sensor from an 06 Corolla work in my dad's 01?
Thanks
SubieHo is offline   Reply With Quote
Old 08-03-2006, 12:59 PM   #2 (permalink)
View tommytuttle's Photo Gallery
Canada
Have you tried cleaning the sensor.
disconnect your negative battery terminal and take out the sensor (two screws)
Once you take it out you can spray it with electrode cleaner. Becareful thought the element inside is pretty fragile.
I usually wait about 15 min for everything to dry they put it all back.
tommytuttle is offline   Reply With Quote
Old 08-03-2006, 05:51 PM   #3 (permalink)
I tried cleaning it a couple of times with non-chorinated brake cleaner. It was covered with oil so I thought cleaning it would do the trick, but the light reappeared about 40 miles later.
The auto section of msn.com notes that the MAF sensor is a relatively common problem for this model year. For some reason, the ones fitted for this car are pretty fragile.
Are others experiencing this problem?
Old 08-03-2006, 09:32 PM   #4 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
There are quite a few people on here that are experiancing the same problem at the moment. Unfortunately it is just a case of clean it or replace it
Not much else you can do... So long as the part number is the same between MAF sensors - they will work correctly...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Intake System Question 01FIERA Archived Corolla threads 18 01-05-2006 08:50 AM
MAF sensor question. cashcrazy Archived Corolla threads 3 10-10-2005 10:11 AM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
How to check if MAF sensor is good, spark plug question kulkarni_ash Archived Corolla threads 6 09-03-2005 12:58 PM
