ok, this is the third time i have had to do this because the thing keeps signing me out.
you would have to hack the car to get it 200lbs heavier than the elise. which wouldnt be good.
the 2003 + car is crummy and cheaply built. the seats are for sumo wrestlers and its a big, clumsy tall car. it has nothing in common with corollas built anywhere else really, and was made just for the N.A. market.
dont waste your money on a new car, it'll depreciate like crazy, buy a 2002 corolla for less than 15k canadian and get a much nicer can, you can pop in a 1ZZ a 2ZZ or even a 4AGE 20V, the car actually shares some similarities with other markets corollas so it wont be as much of a pain to pop in a 4AGE 20V. the engine mounting spots might be fairly similar.
VS.
2002 Corolla < 2003+ corolla
(the 02 is better.)
2002 Corolla
2002 Toyota Corolla Performance-1,794 cc 1.8 liters 4 in-line front engine with 79 mm bore, 91.5 mm stroke, 10 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
-Unleaded fuel
-Fuel economy EPA highway (l/100km): 5.7
-Multi-point injection fuel system
-Main 50 liter unleaded fuel tank
-Power: SAE and 93 kW , 125 HP @ 5,800 rpm; 125 ft lb , 169 Nm @ 4,000 rpm
2002 Toyota Corolla Handling-Two disc brakes including two ventilated discs
-Spacesaver steel rim internal spare wheel
-Strut front and rear suspension with stabilizer bar independent with coil springs
2002 Toyota Corolla Exterior-Body side molding
-Front and rear body color bumpers
-Coefficient of drag: 0.31
-Day time running lights
-Driver and passenger internally adjustable black door mirrors
-External dimensions: overall length (mm): 4,420, overall width (mm): 1,694, overall height (mm): 1,384, wheelbase (mm): 2,464, front track (mm): 1,461, rear track (mm): 1,450 and curb to curb turning circle (mm): 9,815
-Complex surface lens halogen bulb headlights
-Metallic paint , black paint , gloss paint , mica paint , pearl paint
-Rear window
-Tinted glass on cabin
-Weights: curb weight (kg) 1,109
-Windshield wipers with variable intermittent wipe
2002 Toyota Corolla Interior-12v power outlet: front
-A pillar antenna
-Front ashtray
-Manufacturer's own audio system with AM/FM
-Cargo area light
-Cargo capacity: all seats in place (liters): 343
-Front seats cigar lighter
-Clock
-Dashboard and floor full console with covered storage box
-Delayed/fade courtesy lights
-Front seats and rear seats cup holders
-Door ajar warning
-Door pockets/bins for driver seat and passenger seat
-External temperature
-Floor covering: carpet in load area
-Driver and passenger front airbag
-Bucket seat
-3-point reel height adjustable front seat belts on driver seat and passenger seat with pre-tensioners
-Front seat center armrest
-Glove compartment
-Height adjustable two head restraints on front seats and rear seats
-Headlight control with dusk sensor
-Internal dimensions: front headroom (mm): 998, rear headroom (mm): 937, front hip room (mm): 1,283, rear hip room (mm): 1,300, front leg room (mm): 1,080, rear leg room (mm): 843, front shoulder room (mm): 1,341, rear shoulder room (mm): 1,326 and interior volume (liters): 2,492
-Low fuel level warning
-Low washer fluid level warning
-Power steering
-Front reading lights
-3-point reel rear seat belts on driver side, passenger side and center side
-Bench asymmetrical three rear seats
-Rear view mirror
-Remote fuel filler door release
-Mechanical remote trunk/hatch release
-Upgraded cloth/velour seat upholstery with additional upgraded cloth/velour
-Seating: five seats
-Four speakers
-Plastic steering wheel
-Tachometer
-Driver and passenger vanity mirror
-Ventilation system with recirculation setting
http://internetautoguide.com/car-spe...lla/index.html
2003+Corolla
2003 Toyota Corolla Performance-1,794 cc 1.8 liters 4 in-line front engine with 79 mm bore, 91.4 mm stroke, 10 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
-Unleaded fuel
-Fuel economy EPA highway (l/100km): 6.2
-Power: SAE and 97 kW , 130 HP @ 6,000 rpm; 125 ft lb , 169 Nm @ 4,200 rpm
2003 Toyota Corolla Handling-Two disc brakes including two ventilated discs
-Strut front suspension with stabilizer bar independent with coil springs , torsion beam rear suspension with stabilizer bar semi-independent with coil springs
2003 Toyota Corolla Exterior-Body side molding
-Driver and passenger power body color door mirrors
-External dimensions: overall length (mm): 4,529, overall width (mm): 1,699, overall height (mm): 1,466, wheelbase (mm): 2,601, front track (mm): 1,481, rear track (mm): 1,461 and curb to curb turning circle (mm): 10,424
-Luxury trim
-Metallic paint , black paint , gloss paint , pearl paint
-Fixed rear window
-Weights: curb weight (kg) 1,175
2003 Toyota Corolla Interior-12v power outlet: front
-Air conditioning
-Roof antenna
-Cargo area light
-Cargo capacity: all seats in place (liters): 385
-Clock
-Front seats cup holders , rear seats cup holders
-Door ajar warning
-Bucket seat , bucket seat
-Glove compartment
-Illuminated entry system
-Internal dimensions: front headroom (mm): 993, rear headroom (mm): 942, front hip room (mm): 1,318, rear hip room (mm): 1,173, front leg room (mm): 1,049, rear leg room (mm): 899, front shoulder room (mm): 1,349, rear shoulder room (mm): 1,359 and interior volume (liters): 2,557
-Remote power locks
-Power steering
-Front power windows with one one-touch , rear power windows
-Rear view mirror
-Four speakers
-Tachometer
-Ventilation system with recirculation setting and micro filter
http://www.internetautoguide.com/car...lla/index.html
