Circuit Open relay click - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2006, 04:37 AM   #1 (permalink)
View webyosan's Photo Gallery
The car runs fine and doesn't stall, but everytime I press the gas up pass 3k rpm and shift to the next gear, it clicks but still runs?! I adjusted the idle screw idle the car under 1k rpm and diagnose code is 1..Is the fuel pump dying?
webyosan is offline   Reply With Quote
Old 08-03-2006, 06:57 PM   #2 (permalink)
View toyomoho's Photo Gallery
What does clicks mean? Code 1 may mean “normal.”
Old 08-04-2006, 08:43 PM   #3 (permalink)
Gameroom cash: $134355
fuel pump should be held on constantly with the COR..... if it's an auto then it may be shifting the trans (haven't dealt with an electronic auto and the COR).
if it's a manual... it shouldn't be clicking unless you have some sort of light that changes with the gears??? (no idea... you didn't mention car, year, trim, etc....)
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Left rear door wont open!! PoR2GeEzCamry Camry & Solara Lounge 6 06-30-2006 07:46 PM
Auto window down circuit cambre Camry & Solara Lounge 0 10-04-2005 12:30 PM
Need Major Help!! relay block 6 in gen3? electric henry bui 3rd & 4th Generation (1992–1996 & 1997–2001) 2 05-22-2002 02:21 PM
Open circuit relay BIGJUICECAMRY Camry & Solara Lounge 0 04-09-2002 04:26 PM
