2001 corolla scheduled maintenance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-04-2006, 12:37 PM   #1 (permalink)
View pitbull30's Photo Gallery
I bought my 01 from the dealer with 44k on it. It is now at 71k.
I havent done anything to it besides change the oil around every 3000 miles.
I was thinking about taking it to have the dealer recommended scheduled maintenance done. Trans oil, plugs, fuel filter, etc etc.
They alwys have those package deals for 159.00 and it includes everything. Except of course if it needs platinum or iridium plugs.
So my questions are:
Does the 01 require special plugs?
Should I be taking it in for this maintenance already or should i wait a longer?
Also the dealer recommends the timing chain be replaced? Should I maybe do this first?
Like I said i bought it from the dealer so I have no idea what is in it or what thye did to it before they sold it to me.
pitbull30 is offline   Reply With Quote
Old 08-05-2006, 03:52 PM   #2 (permalink)
bump[
Old 08-05-2006, 11:19 PM   #3 (permalink)
JZ TWINS's Avatar
View JZ TWINS's Photo Gallery
Are you sure they didnt say timing chain tensioner. They have an oring that leaks. Maybe even your drive belt tensioner. They come with iridium plugs. Good till 90-100k. For the fuel filter, Toyota doesnt recommend you change them till after 100k.
JZ TWINS is offline   Reply With Quote
Old 08-06-2006, 07:48 PM   #4 (permalink)
Thanks for the reply. I guess I will wait awhile then. I read the same thing somewhere else about the plugs being good until 90k.
Old 08-06-2006, 08:10 PM   #5 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
You should have at least changed your air filter every 12k...Do you have a cabin filter? check that, after one year mine was filthy..How about inspecting and adjusting your rear brakes...Lube that EB so it doesn't freeze up in a few years...Original battery after 5 years it might not be good for this winter, check it out...How about your serpentine belt, any cracks?...Wheel alignment?...I think your fuel filter is in the gas tank(not sure)...good luck
~Radd
Raddman is offline   Reply With Quote
Old 08-06-2006, 11:16 PM   #6 (permalink)
I have done the air filter and brakes. Belt is good. No crack. I do a visual check everytime I check my oil. Never changed the cabin filter.
Thanks for the tips i will check into them.
Old 08-07-2006, 11:24 AM   #7 (permalink)
JZ TWINS's Avatar
There is no cabin air filter on your car. Maybe a coolant flush
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
2001 Corolla Starting problem - Fuel Filter theguy 8th Generation (1998-2002) 6 12-31-2008 10:42 PM
Any "angel eyes" for 2001 Corolla 200CorollaS2001 Archived Corolla threads 5 10-18-2005 10:38 PM
