best thing to use on lock tumblers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-04-2006, 08:53 PM   #1 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
AE92 best thing to use on lock tumblers
Redoing the lock tumblers for my door and I was wonder what you guys suggest I buy to put in them to stop them from coroding and siezing. I have been told graphite, but I still thought just in case, better check.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 08-04-2006, 09:19 PM   #2 (permalink)
Infrequent poster
View Crump's brother's Photo Gallery
Go to kanolabs.com and pick up some Molyfilm. They are the same folks that make Kroil, which is so much better than WD/PB Blaster is isn't fair.
I realize that this is my first post, so it may seem suspicious, but I am in no way affiliated with that company. Best of luck...
Crump's brother is offline   Reply With Quote
Old 08-04-2006, 09:30 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
hehe.. you gave your 2cents that's what counts.
I believe lithium grease will also work, but don't quote me on that though. Or you can ask Toyota what that stuff they have on their cans that they spray on the door hinges is, that will also work.
Old 08-04-2006, 09:37 PM   #4 (permalink)
mickeyd's Avatar
View mickeyd's Photo Gallery
If you don't have keyless entry, liquid grafiite is great to help unseize door locks.
mickeyd is offline   Reply With Quote
Old 08-04-2006, 10:03 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
well I bought 2 handles from the wrecker since I broke my driver one when I got fustrated and just pulled on it breaking the tab and back of the tubler plus the handle was already cracked. best thing is I got the key for these handles too, and the tumblers work! just wanted to clean them up and find something to put in them so they don't seize like the other ones did last winter
Old 08-05-2006, 01:02 AM   #6 (permalink)
View Burger_AE102's Photo Gallery
I don't know if it's available in the US, I'm sure it will be, but we have a lot of dry lube products in Aus, like waxes, that are great for locks. You really want to use something graphite or a wax because they are dry lubes and not liquids (WD40, teflon lubes etc). If you use a wet lube you're going to get lubricant on your keys and all through every set of pants you own!
Corolla, don't leave home without it.
Burger_AE102 is offline   Reply With Quote
Old 08-05-2006, 08:35 PM   #7 (permalink)
gts-rated
xrated3345's Avatar
View xrated3345's Photo Gallery
yea just go with ur fisrt tought graphite. its cheap small bottle at autozone 4 bux
http://www.myspace.com/13833694
xrated3345 is offline   Reply With Quote
Old 08-05-2006, 09:28 PM   #8 (permalink)
Vroom?
freakinbox's Avatar
yea thats what I did. was going to be lazy and just use the other key I had but meh took all the handles apart and made one good handle for each side that worked with the orginal key. Also figured out how to get the handle out without having to unlock it to slip it out!
Old 08-07-2006, 11:51 AM   #9 (permalink)
View 96_9c1's Photo Gallery
DO NOT USE GRAPHITE!
Graphite will start gumming up, making the springs and tumblers stick.
Locks have small tolerances, so adding something like graphite will make those tolerances even smaller.
Try a spray called Houdini, which is used by locksmiths
96_9c1 is offline   Reply With Quote
Old 08-07-2006, 12:34 PM   #10 (permalink)
Vroom?
freakinbox's Avatar
meh I already did it the other day, bought some liquid graphite. If it gums up I will fix it. The only reason they stopped working was nothing was there to keep the crap from the winter from sticking to them
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
where to find pop n lock SJlittlefoot 2nd Generation (2005+) 3 03-22-2006 06:57 PM
Removal of Trunk Lock? bpoppe4 Camry & Solara Lounge 3 02-29-2004 12:35 AM
