a few fuel system questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2006, 10:07 AM   #1 (permalink)
View danno177's Photo Gallery
AE92 a few fuel system questions
ok i just got this car its a 91 corolla 4 door and the lines were rotten on the intake one going fomt the bottom off the intake to the throttle body part what does this one do? that one acually broke off very close to the intake does this come off to replace ? and if anyone knows where to find a fuel system diagram id really apreciate it thanks alot
danny
danno177 is offline   Reply With Quote
Old 08-05-2006, 11:23 AM   #2 (permalink)
View tashirosgt's Photo Gallery
Are your sure these are fuel lines? If you have a 4AFE engine, look near the rear of the head and see if you see something that looks like a section of pipe. That would be the fuel "rail" that sends fuel to the injectos. On the drivers end of that is a fuel line. As I recall, this line goes directly to the fuel filter. The smaller lines in the vicinity of the throttle are mostly vacuum lines.
tashirosgt is offline   Reply With Quote
Old 08-05-2006, 04:52 PM   #3 (permalink)
yes you are correct my engine is a 4afe . the steel line that broke comes from the bottom of the intake then a rubber hose goes over it and the it conects to a steel lines into the throttle body . are you saying this is a vacuum? how do you get the line out of the aluminum manifold?
Old 08-05-2006, 10:27 PM   #4 (permalink)
You'll have to give me some more landmarks. I'm not sure what you are calling "the manifold". There is a small metal fuel ine from near the middle of the "fuel ail" to the cold start injectory which is in the part of the intake that is downstream from what the service manual calls the throttle body. There is a "vacuum sensing" hose that runs from the fuel pressure regulator (which is on the passengers side of the fuel rail) to the same area.
fuel system promblems aleard5 89-95 Toyota Pickup/Hilux 7 12-17-2007 11:08 AM
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 11:30 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
