4A-FE Turbo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2006, 06:30 PM   #1 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
4A-FE Turbo
Time has come for me to turbo
Please bare with me now, i'm new to the world of turbochargers and I'm excited. I'm so used to building american v8s, now is my chance to build a fast 4 cyl that gets 25 mpg.
I'm looking for a turbo exhaust manifold to start with. Making one would be a pain, and im sure there are some out there, what are my opions? I'm looking to run no more than 6lbs of boost to keep my engine happy. I could probably get by with a basic t3 turbo. I also want to run an intercooler setup which isn't that hard, just finding on that fits, and fabbing up some lines.
So my point is this, I know how to make everything bolt up and work physically, but what else do I need to do electronically to make it run? Also, how do I run an oil feed line to the turbo? Just drill a hole in the pan, tap it and run a line?
I looked at the wiring for this car, for Fuel Injection, its very simple and basic, i think I can pull this off. just need some advice and assistance.
TheOtherCarolla is offline   Reply With Quote
Old 08-05-2006, 06:53 PM   #2 (permalink)
4AFESPEED
My only question is where does the MAP sensor go? Can I just leave everything else alone and simply bolt up the turbo pieces?
Old 08-06-2006, 03:11 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Map sensor will stay in the manifold like its supposed to. problem is that it doesnt read boost and the ecu doesnt know how to dictate it.
SUPPOSEDLY, now I've never done this, so I cant vouch for it, BUT some boys _supposedly_ have. you install a checkvalve into the map sensor tubing and a T which you create a controlled leak, now supposedly the map sensor will work with that. Then you use a FMU device to raise the fuel pressure with a ratio to boost. I take no responsibility with this.
you probably wont get 25 MPG with a turbo.
Next, buy two books Street turbocharging and corky bell's maximum boost. Its gonna clear alot of things up and give you knowledge about this.
Old 08-06-2006, 07:58 AM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
could have drawn that in paint shop lol instead of scanning. BUt non the less covered a few things I didn't know since I haven't done research on a turbo set up before
those black circles are the strut towers?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 08-06-2006, 08:30 AM   #5 (permalink)
4AFESPEED
yes they are. Not exactly to scale, just trying to get an idea. So the only thing I need to do is figure out how to make the ecu understand boost since it can read above 1 bar.
Old 08-06-2006, 09:20 AM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
go with standalone ECU, it will undestand ANY boost.
Old 08-06-2006, 09:41 AM   #7 (permalink)
4AFESPEED
I'm not looking to go that in detail with this setup. I just need to make it work.
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
Old 08-06-2006, 07:30 PM   #8 (permalink)
4AFESPEED
Do celica, mr2 headers bolt up the same as a 4af3 engine? Would this work?
http://cgi.ebay.com/ebaymotors/ws/eB...m=260015797502
Old 08-06-2006, 09:36 PM   #9 (permalink)
The TN Member
View punter's Photo Gallery
No they won't bolt up, you'll need a custom manifold.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 08-06-2006, 10:01 PM   #10 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
Once you get your mani fabbed up, you can get a rising rate FPR, and isolate your MAP sensor with check valves. It's a cheap and crude way of doing it, but it does work.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 08-07-2006, 01:12 AM   #11 (permalink)
KDM is in
REN69's Avatar
I believe the OEM ECU will work ok with 4-5psi.. not sure how much that is in bars.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 08-07-2006, 06:22 AM   #12 (permalink)
The TN Member
Stock it should deal with a little boost, For a while
A guy over here turbo'd a 5afe (1500cc version of your engine) using the standard ECU, with a 2 bar map sensor from a GTS mr2 and ingectors from a supra (I can't remember the CC rating.) The lower reading from the map sensor was offset by the larger injectors (also had a Rising Rate FPR) which allow about 8psi boost. the limiting factor was that the NA ecu won't retard the timing for boost.
Old 08-07-2006, 09:46 AM   #13 (permalink)
4AFESPEED
So if i were to try to find an MR2 turbo map sensor, larger injectors and cam gears to retard the timing, I could run 4-5 psi safely?
Old 08-07-2006, 09:47 AM   #14 (permalink)
4AFESPEED
Where can I pick up these parts?
Old 08-07-2006, 01:18 PM   #15 (permalink)
Resident asshole
Flashmn's Avatar
You dont retard ignition timing by turning the cams around, thats cam timing.
As for where you can buy those parts:
performance shops.
Seriously though, maybe you should buy a few books and study this subject a bit, otherwise you're going down shit-creek very damn fast. Just a suggestion from my point of view.
My Official Turbo Post!!! 97camryman Camry & Solara Lounge 25 07-20-2006 04:48 PM
More boring ?'s about N/A turbo mod namr2 MR2 Forum 12 03-01-2005 01:33 AM
4a fe head on 4age block fleetwood dicki Hardcore Tech and Competition 3 02-15-2005 12:03 PM
oil and turbo eclypz MR2 Forum 9 08-03-2004 07:15 AM
are the non turbo and turbo the same? blitzed95eclips MR2 Forum 3 05-01-2003 03:17 PM
