ae92 gts brakes on sr5 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2006, 06:46 PM   #1 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
AE92 ae92 gts brakes on sr5
Will my 13" rims still fit over them? Do I have to change the master cylinder or it just as simple as changing the caliper and bracket for the caliper?
just for future referance to do the rear do I have to change the lines or master cylinder, I would think I'd have to but hey maybe I'm wrong
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 08-08-2006, 12:03 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Only the 90 and up GTS have the bigger rotors up front, the rears are the same on all years.
Old 08-08-2006, 12:22 AM   #3 (permalink)
Vroom?
freakinbox's Avatar
but is the rest of the brake system is the same? so really people saying the sr5 brake system is bad was stupid? :s
Old 08-08-2006, 05:54 AM   #4 (permalink)
KDM is in
REN69's Avatar
I think what they meant was not "as good" since they're drum on the back. The disc are the same up front on both cars up to 90, then they changed to bigger disc up front for the GTS but they kept the smaller discs on the SR5s.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 08-08-2006, 09:39 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Yes they will. No you wont have to change the master cyl, but you have to change the proportioning valve. But unless you do track driving, or the law demands you have disk brakes in the back (they do here when you turbocharge), I'd stick to the drums. The disks suck.
Old 08-08-2006, 11:53 AM   #6 (permalink)
Vroom?
freakinbox's Avatar
now for the proportioning valve is that just if I do the rear brakes?
as for the sr5 brakes sucking... than thats just stupid. Since the drums on the ae92 are pretty large. Most of the newer cars with mor weight to them have smaller rear drum brakes than the ae92....
Old 08-08-2006, 01:27 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Yeah, like that
No I said the GTi/GTS disks suck.
Old 08-08-2006, 04:55 PM   #8 (permalink)
Vroom?
freakinbox's Avatar
because I was thinking I could shove the 90+ larger front brakes on my car. I really need to find a gts parts car lol
while we are on this topic. I figure you would know flashmn umm with the gts and sr5 are the rear suspensions actually different?
Old 08-08-2006, 05:02 PM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Springs are different, I think the shocks are too. Otherwise it should be quite same. Atleast I havent seen any real differences, then again I havent been under the car with a vernier caliper either. The rear knuckles are different to house the disk brakes. But you can put AE82 rear disk calipers and call it a day. The piston is slightly bigger, 2mm in diameter versus the AE92 rear caliper. The AE82 caliper mounting bracket goes between the hub and knuckle, so its alot easier to install than the AE92 version.
Old 08-08-2006, 07:21 PM   #10 (permalink)
Vroom?
freakinbox's Avatar
was just reading on a site that the gts has
4-link w/ lateral track rod, double-acting hydraulic shock absorbers and stabilizer bar
and the sr5 and sedans have
Independent dual link w/ MacPherson struts, low-pressure gas-filled shock absorbers
http://www.ae92gts.com/ae92gts_gen_dim.html
Old 08-08-2006, 10:45 PM   #11 (permalink)
KDM is in
REN69's Avatar
You're wrong, the 13inch wheels won't fit over the 90 GTS front rotors.. I've tried.
Old 08-09-2006, 02:56 AM   #12 (permalink)
Vroom?
freakinbox's Avatar
lol well then as for that idea, it's out until I feel like getting a set of 14's and new snow tires since right now I only need a rim and a snow tire rather than 4 of both :p
Old 08-09-2006, 09:56 AM   #13 (permalink)
Resident asshole
Flashmn's Avatar
get AT171 front brakes. They're thicker than the GTS disks. 238x22mm.
sr5 to gts newb Archived Corolla threads 4 11-14-2005 12:30 PM
1990.5 AE92 GTS for sale RedruM Vehicles 28 03-04-2005 08:29 AM
84 sr5 swap to gts 07734 Archived Corolla threads 4 06-28-2004 08:26 AM
