Runs well cold; stalls when hot, after head replacement
I replaced a head gasket on a '95 Corolla, 1.8 engine. The car runs well when cold, but after the car warms up, the cars run well in park -- revs up high - no problems. But, when I try to drive it, it stalls out. In reverse, it seems to be ok. When I drive the car, it stalls and is hard to start -- again, the engine is strong in neutral -- but sputters under pressure. After it sits up for 10 minutes, it starts easily and runs well in park.
Any ideas as to what was not set up properly in putting the engine back together? We took off the manifolds and all connectors, etc. Any suggestions as to what I should be looking for as a problem area will be helpful.
Reason: Better focus on problem know that I know more
