Difference between Silver and Black top - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2006, 02:41 PM   #1 (permalink)
View AE86Sideways's Photo Gallery
i am going to swap a 20v 4age into my 86 and i was wondering whats the difference between a silver top and black top.
AE86Sideways is offline   Reply With Quote
Old 08-10-2006, 04:07 PM   #2 (permalink)
The TN Member
View punter's Photo Gallery
Originally Posted by Redmist
I don't want to start a debate in regards to the benefits of the changes from silvertop to blacktop (it's been done a million times before and will be done a million times in the future) however I wanted to list everything that was physically changed between the two engines. I've stripped down both but have more than likely missed several of the changes.
Blacktop changes over facelift silvertop.
Intake...
-Airbox, larger capacity and bigger entrance.
-Trumpets are now made of rubber (silvertop are plastic), and are bigger in diameter (approximately the same length)
-TB now have a 45mm butterfly as opposed to the 43mm of the silvertop.
-TB's have a taper to the floor of the TB which mates into a taper in the manifold. IE TB to manifold face the TB looks like a D with the bottom of the TB filled in. Silvertop TB's have no taper in the floor, floor taper only occurs in the manifold.
- Manifold has slightly different shape to port entrance. A smoothing of the teardrop shape as introduced on the facelift silvertop. Ports are also bigger.
- Vacuum balancel now cast into the face of the manifold. Silvertop runs with an external collector based under the TB's.
- Blacktops are MAP sensored whereas Silvertops run AFM.
HEAD...
- Bigger intake port.
- Small port dividers. Silvertop has none.
- Open combustion chamber, silvertop has squish bands on both inlet and exhaust. (closed combustion chamber)
- Exhaust port is approximately 20% bigger in volume than the Silvertop.
- Cam Bucket fences are remoulded to hold more oil, but appear to allow for more cam lift.
- Additional support ribbing from sparkplug holes to cambearing platforms.
- Inlet cam has slightly more lift.
- Anyone cc'ed the combustion chambers?
INTERNALS.
- Same Crank. Based upon P/N. Also viewing cranks.
- Rods, noticeably lighter, smoother radiuses on all projections/ joins.
- Pistons have smaller valve relief’s in surface. Silvertop has 5 pronounced valve releases, Blacktop only 3 intake are visible. 2 Exhaust do not exist.
BLOCK....
- Blacktop uses a hydrolic cam belt tensioner whereas the Silvertop uses a spring arrangement.
GENERAL...
Exhaust manifold is much larger to mate to the larger exhuast ports.
Compression ratio raised to 11:1 from 10.5:1 on the silvertop.
That just about covers it.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 08-10-2006, 04:13 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
What punter said.. and the fact that one is Silver and one is black.
Old 08-10-2006, 04:20 PM   #4 (permalink)
The TN Member
I knew I forgot something
Old 08-10-2006, 04:23 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I glanced over it, silvertop shares the connecting rods with the 4agze which is why it's more common to have FI due to them already being out of a FI engine
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 08-10-2006, 08:30 PM   #6 (permalink)
View micro214_kp61's Photo Gallery
this is news to me. i thought all 4AGEs have the same size of exhaust ports. can anyone confirm this? thanks!
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 08-11-2006, 12:05 AM   #7 (permalink)
operation boro thunder
View project trueno's Photo Gallery
^2mm larger than ST
project trueno is offline   Reply With Quote
Old 08-11-2006, 03:20 AM   #8 (permalink)
The TN Member
Yea the blacktop has far better exhaust ports, flows much more than a silvertop.
That said, there is only 5hp between them in standard form.
Old 08-11-2006, 07:00 AM   #9 (permalink)
i thought for sure the only difference was on the intake ports and none on the exhaust. that's good to know.. thanks guys!
Old 08-11-2006, 01:01 PM   #10 (permalink)
whats the differences in them spec wise? horespower, redline, torque, etc.
Old 08-11-2006, 04:54 PM   #11 (permalink)
KDM is in
REN69's Avatar
Searching usually works wonders.. lots of sites with information, here's a couple of links.
http://my.tele2.ee/levintrueno/engine/engine.htm
http://www.club4ag.com/technical_mai...tions and Data
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 08-12-2006, 12:00 AM   #12 (permalink)
Vroom?
freakinbox's Avatar
well with the 20v's it's hard to find the hp rating since most are the toyota one on those sites and well people say toyota exagerated the power ratings in those engines
Old 08-13-2006, 12:22 AM   #13 (permalink)
The TN Member
Actual engine dyno readings done in Australia show 144hp for blacktop and 138hp for the silvertop. That’s freshly rebuild motors, completely standard.
So yes toyota lie about power figures, but before rubbishing 20v's keep in mind the fact that the 16v 4age's would have been measured in the same way.
Old 08-13-2006, 12:52 AM   #14 (permalink)
View rice's Photo Gallery
^thats true, although i've heard they use higher rating gasoline in japan, thats why when we dyno the 20vs' over here we get a much less hp rating
rice is offline   Reply With Quote
Old 08-13-2006, 01:12 AM   #15 (permalink)
The TN Member
In Aus an NA we can get 98 octane so not that different to japans 100
Black nerfs on a Silver Taco? ghindman 2nd Generation (2005+) 9 01-26-2006 12:48 PM
4age silver top and black top 914afe1331 Archived Corolla threads 9 08-20-2005 07:05 PM
3rd gen camry (SILVER) with black rims BuDDHa510 Show & Share 10 06-01-2005 09:25 AM
20V black top proj kpsxtyone Hardcore Tech and Competition 6 03-09-2003 12:44 PM
4age20 silver or black top in 5th gen st celica/camry Celica Forum 1 02-03-2003 08:42 AM
