check engine light comes and goes away... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2006, 01:20 PM   #1 (permalink)
View Trueno90Deuce's Photo Gallery
AE92 check engine light comes and goes away...
everything feels to be functioning ok... but after driving a while my check engine light lights up for sec and then goes away.
I see no correlations with temperature or oil pressure.
the longer I drive the longer it takes to go away after it lights up... as the days go by it comes on sooner than usual and stays on longer...
anyone know whats going on or where to look?
1988 corolla gts
Trueno90Deuce is offline   Reply With Quote
Old 08-12-2006, 02:01 PM   #2 (permalink)
View toyomoho's Photo Gallery
Could be the 02 sensor. Can you read the trouble codes?
Old 08-12-2006, 02:06 PM   #3 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
Sounds like a frayed wire picking up moisture and "shorting it out"
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
TheOtherCarolla is offline   Reply With Quote
Old 08-14-2006, 07:05 PM   #4 (permalink)
AE92
well i tried to read the codes by using a paper clip to connect the terminals but i dont find any code according to my haynes manual.... all it does is make the check engine light blink like a turn signal infinite times....
Old 08-14-2006, 08:15 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Well yeah.. find a pattern in the blinking, it might go short short, then long blink OR short long short long, etc.. there's always a pattern in the blinking once you've shorted the terminals; then you reference that pattern to the codes.
Old 08-14-2006, 08:33 PM   #6 (permalink)
AE92
I'm well aware of that, thank you for thinking so highly of me ... there is no pattern just blinks constantly.. no pauses.... seriously haha
Old 08-14-2006, 09:22 PM   #7 (permalink)
The TN Member
View punter's Photo Gallery
Constant even blinking means no error codes.
Could be an ecu fault, or perhaps speed sensor fault. Any other fault and the ECU would remember it.
does it happen ever time you drive it.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 08-14-2006, 09:32 PM   #8 (permalink)
AE92
ahhh... well maybe that's what it's refering to if what you're saying is right. My speedometer cable broke, so I'm always going 0 mph. However, it did not trigger the day it broke, it lit up days after. Also it only lights up after about 20 minutes of driving... on and off inconsistently, any more driving than 20 minutes it stays on.
it is constant even blinking, but correct me if I'm wrong... doesn't it have to be even blinking with pauses between each blink to mean that nothings wrong?
I have it blinking rapidly, evenly, and relentlessly with no breaks...
thanks guys for being attentive to my matter by the way
