a/c lowend pressure valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2006, 03:51 PM   #1 (permalink)
csn
View csn's Photo Gallery
AE92 a/c lowend pressure valve
Which one is the low end pressure valve on a 89 gt-s. There seem to be 2 ac valves next each other. One is a few inches higher than the other and a few more inches away from the fire wall. ????
~Chris
Newbies learn the hardway!!!!!
csn is offline   Reply With Quote
Old 08-12-2006, 09:47 PM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
try this A/C forum:
http://www.acsource.net/acforum/
retiredat44 is offline   Reply With Quote
Old 08-13-2006, 01:23 PM   #3 (permalink)
csn
Originally Posted by retiredat44
Nope did not help to much. Is the low pressure the big line or the small line. Some of you that have already done this should know. I can't tell exactly where the lines are running just to many turns and to much stuff obstucting my view. Someone give up the answer.
~Chris
Old 08-13-2006, 10:04 PM   #4 (permalink)
Cool
big tube line from firewall (evaporator) to Compressor is Low Pressure.
did you actually post a question on the a/c forum?
Old 08-14-2006, 11:38 AM   #5 (permalink)
csn
No I did not post a question on the A/C forum. But thanks for that answer though. I think that gets me going.
~Chris
Old 08-14-2006, 01:06 PM   #6 (permalink)
Exclamation
info:
http://www.familycar.com/Classroom/ac1.htm
hope you don't get into trouble.. that's why I gave you the forum link, to make sure you get a problem fixed..
How-To Guide: Removing and Painting a Valve Cover - 5SFE -- 56K warned Lots of Pics RedPhoenix 3rd & 4th Generation (1992–1996 & 1997–2001) 72 02-14-2011 09:17 PM
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Oil Leak in 93 Camry LE 3VZ-FE V6 Front Valve Cover or Oil Pressure Switch? Xander 3rd & 4th Generation (1992–1996 & 1997–2001) 0 07-09-2005 05:27 PM
(ISC) Idle Speed Control Valve Travel jackfrost1031 Camry & Solara Lounge 1 04-22-2005 01:26 AM
