fuel gauge fubar, 86 AE82 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2006, 12:55 PM   #1 (permalink)
View 91redtercel's Photo Gallery
Question fuel gauge fubar, 86 AE82
we have a fwd 86 corolla sedan. the fuel guage used to work, i filled the tank and the guage bumped around between 1/4 and 3/4 then dropped to empty and stayed that way for 150 miles then started working for a day, and then quit again.
i found the sender and pulled it out, does anything look wrong?
i metered the wires at the connector both sides of it, i have a yellow/blue wire which reads 12 volt ignition, a white/black which reads ground, and a yellow/red which i would assume is signal, when i move the float up and down manually it will change from no voltage to around 3 volts however if i i just let it sit it will bounce around, 1 volt to 4 then 2 then 3 then 2 again. :o i have about 3/4
1986 corolla sedan- 100% stock except for the alarm...more to come
1990 accord- h22 swapped w/lsd
91redtercel is offline   Reply With Quote
Old 08-13-2006, 02:32 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Just change it dude, my dad's 84 Toyota toaster van used to do the same, the needle would go crazy and sometimes not read if you filled up the tank, then it would start reading again at about a quarter tank. He changed the sender unit and it was good after that.
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
fuel gauge problems?? 1MZ-FExle.s Camry & Solara Lounge 1 04-25-2006 02:25 AM
Fuel Gauge/Engine Temp Gauge straight up 1992Tercel5Spd Tercel, Paseo, Starlet, and Sera Forum 5 02-26-2006 11:35 PM
Fuel gauge problem... TRD 4Runner Off Topic 0 12-11-2001 09:38 PM
