Code 71 Issue????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2006, 08:41 PM   #1 (permalink)
View rfich53's Photo Gallery
Question Code 71 Issue?????
'95 1.8 auto 108k miles. Code 71 Check Engine Light. So far Replaced EGR VSV; then tested egr temp sensor good, removed egr & cleaned slight carbon from egr, egr vac modulator tested good. Symptom besides code 71 is slight gas ping on easy acceleration from stop. Checked timing good. Decarbonized with seafoam. Ran Valvoline fuel cleaner thru 1 tank of gas. Reset ECU and within 20 miles Code 71 re-appears. HELP!!!!!!
And thanks in advance.
rfich53 is offline   Reply With Quote
94 Camry Check Engine Light Code: 71 Check EGR Valve laksh99 3rd & 4th Generation (1992–1996 & 1997–2001) 15 10-29-2011 07:52 AM
CORRECTION: Code 71 Question rfich53 Archived Corolla threads 6 08-02-2006 02:14 PM
Code 71 & Fuel Filter Questions leeave96 Tercel, Paseo, Starlet, and Sera Forum 2 11-19-2005 08:39 AM
check engine code 71 lamedoc Camry & Solara Lounge 14 09-19-2005 05:54 PM
2000 Sienna Air-Fuel Sensor OBDII code issue skriest General Discussion 0 01-31-2005 05:10 PM
