how am i supposed to change M/T gear fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2006, 10:13 PM   #1 (permalink)
Sexy Run
AE92_GTS88's Avatar
View AE92_GTS88's Photo Gallery
AE92 how am i supposed to change M/T gear fluid?
umm what is the procedure in changing gear fluid for the 1988 corolla gts. I already have the fluid i just dont know how to do it.
Thank you
jDm tOIt AIIIIGHT!
Jesus I suck . I apologize for this.
AE92_GTS88 is offline   Reply With Quote
Old 08-15-2006, 12:58 AM   #2 (permalink)
The TN Member
View punter's Photo Gallery
On the front of the gear box there will be a bung/bolt, Its quite big (don't remember the size though) Fill the gearbox up untill its at the bottom of the bung.
Thats about all there is to it really.
A funnel and correctly sized hose will help get the fluid into the gearbox.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 08-15-2006, 01:14 AM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
There should be two bolts on the C-Series box. A drain and a fill. At least i remember there being two...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 08-15-2006, 02:03 AM   #4 (permalink)
Sexy Run
AE92_GTS88's Avatar
will it be the same for the T50 tranny?
jDm tOIt AIIIIGHT!
Old 08-15-2006, 03:57 AM   #5 (permalink)
View karazy's Photo Gallery
There are two plugs on every m/t\gearbox. Just make sure you can get the filler (upper) plug out, before you drain it. You don't want to be stuck with an empty box and no way to fill it.
karazy is offline   Reply With Quote
Old 08-15-2006, 08:54 AM   #6 (permalink)
gts-rated
xrated3345's Avatar
View xrated3345's Photo Gallery
i took mine to yota and they charged me 20 bux. but since you already have the stuff
http://www.myspace.com/13833694
xrated3345 is offline   Reply With Quote
Old 08-15-2006, 11:34 AM   #7 (permalink)
Gameroom cash: $134355
they are 23mm bolts...... the drain will be near the bottom of the trans, and the fill will be about 1/2 way up on the front of the trans
i personally hate using the fill bolt, so i pull the speedo gear out and fill it right there (much easier and faster).
Old 08-15-2006, 11:40 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
below the drivers side inside CV joint.
I prefer to use the front hole to pour the oil in. Get a nice hose, put that in the hole and its easy.
Old 08-15-2006, 05:22 PM   #9 (permalink)
N/A bites
Tercel GTS's Avatar
Here's a really good thread with clear pictures explaining it.
http://board.tercelonline.com/viewthread.php?tid=26688
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-15-2006, 06:53 PM   #10 (permalink)
that's what i used to do... until i figured out the speedometer drivegear trick..... that way you have a direct 1.5" hole in the top of the trans... i use a radiator funnel and pour in the 2.7 (or whatever it is) quarts into the tranny in about 15 seconds & i'm done
1997 Camry Transmission Fluid Change Question cyman73 3rd & 4th Generation (1992–1996 & 1997–2001) 16 12-07-2011 08:10 PM
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
Differential fluid change megamac83 Camry & Solara Lounge 18 11-21-2006 09:59 PM
15K miles trans fluid change? Joe B Archived Corolla threads 3 04-25-2006 05:35 PM
When to change brake fluid? Ken4 Camry & Solara Lounge 2 09-10-2002 08:20 PM
