noob - Just Bought a 1989 Corolla GTS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2006, 05:17 PM   #1 (permalink)
View gongfai's Photo Gallery
AE92 noob - Just Bought a 1989 Corolla GTS
I've been reading a bit on these threads.
I just picked up a 89 corolla gts. looks like i got the 4age but the person who i got this car from told me she had swapped a different engine in it.
by looking at pictures, it looks just like the 4age but it has TVIS also. I read somewhere that 89 gts' aren't supposed to have that. so i don't know what engine i have.
one more thing, i'm not looking to boost the power in this car, but i want to fix it so it can run forever.
any suggestions on what i should change first with this car?
it runs right now, but i don't know how dependable it is.
thanks
gongfai is offline   Reply With Quote
Old 08-15-2006, 05:24 PM   #2 (permalink)
gts-rated
xrated3345's Avatar
View xrated3345's Photo Gallery
i have an 89 w/ tvis so your good. i.m.o just oil change plugs wires cap rotor. and clean the motor so if you do have an oil leak you can catch it. o and welcome.
http://www.myspace.com/13833694
xrated3345 is offline   Reply With Quote
Old 08-15-2006, 05:30 PM   #3 (permalink)
should I get new headers and intake kit? I want to make it run better, but i don't want it to be loud like a rice rocket... get pulled over too much in cali.
Old 08-15-2006, 06:25 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
89 was the last year for the TVIS big port 4age in the ae92. 1990 had the smallport 4age which had more power than the big port.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 08-15-2006, 07:12 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Ask REN he has an 89 and a 90 GTS.. oh wait that's me! The 88-89 GTS 4AGE has TVIS the 90-91 Smallport GTS doesn't.
89 GTS
90 GTS
For intake kits, you have to get a cone filter and an AFM adaptor kinda like my cars, there's a few places on the internet selling the kits. Here's a kit that I might get from Cosmo Racing in Canada.
http://www.cosmoracing.com/productin...id=126&pid=307
As for headers, they're hard to find, if you can find them get them.
Old 08-15-2006, 08:01 PM   #6 (permalink)
Vroom?
freakinbox's Avatar
as for swapping the motor could it possibly be the 3 rib 4a block rather than the 7?
interesting fact I just noticed, suposidly the 4age big port in the ae92 has 125 hp rather than the 118 of the 3 rib 4age.
if your wondering what TVIS is well...
"TVIS is a set of butterflies that close off one of the intake valve ports below 4500 rpm to increase air flow and fuel atomisation. They are operated by manifold vacuum. Engines without TVIS (ie post 89.5 red Tops) have smaller intake ports."
It is suposed to make the engine feel more powerful through the lower RPM.
Old 08-15-2006, 11:37 PM   #7 (permalink)
KDM is in
REN69's Avatar
haha.. TVIS sounds cool at 4500rpm when you have a cone filter installed on your intake, I remember on the highway once the revs would hit 4500rpm the butterflies opened up and it would sound like a mean beast.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 08-16-2006, 12:11 PM   #8 (permalink)
Gameroom cash: $134355
the 7 rib big port does NOT have significant more power than a 3 rib...... in fact, the cams have a slightly smaller duration (yes, between bigports... smallport cams are even smaller than either bigport cams) and a heavier rotating assembly (bigger/thicker rods & crank).
the few extra HP that the 7 rib "claims" isn't because of the engine... it's slightly better electronics and larger injectors....
*however* there are some *very rare* late 89 factory bigports that have a bigport head, a bigport block, and smallport rotating assembly. We're pretty sure a friend of mine has one in his aw11 (his is a late 89... late enough to where toyota changed the rear hub assemblies BACK to the early aw11's.... that was only done in the last few months of production).... completely stock except for a very very dirty cone filter (and leaking/burning oil) he dyno'd at 108whp.
Old 08-16-2006, 03:58 PM   #9 (permalink)
Vroom?
freakinbox's Avatar
I am not even thinking about the power difference but more the fact the 3 rib is a weaker block.
Old 08-17-2006, 04:53 PM   #10 (permalink)
Question
how can you tell which block do you have? sorry to ask but, how do you know if you have a 3 rib or 7 rib block?
Old 08-17-2006, 11:52 PM   #11 (permalink)
KDM is in
REN69's Avatar
I think the AE92s with the 4AGE already had the 7rib blocks.. if I'm not mistaken (so correct me if I am) the AE86s near the end of their production (1987) had the mixed 3 and 7 ribs motors.
Old 08-18-2006, 01:57 AM   #12 (permalink)
Vroom?
freakinbox's Avatar
thats what I thought, the ae92 had 7 ribs. But if the engine was changed he can't just go buy what the ae92 has
Old 08-18-2006, 04:52 PM   #13 (permalink)
My engine looks just like Ren's first picture (89 rolla) but cleaner. =P
so i'm pretty sure it's ae92 4age engine.
So far i've changed the power steering cable and changed the oil. I'm planning on changing the spark plugs and wires next. Any suggestions? otherwise i'm just picking some up from AutoZone.
what else should i change before taking it out for a joy ride?
Old 08-18-2006, 07:37 PM   #14 (permalink)
Vroom?
freakinbox's Avatar
valve covers are interchangeable, if they were painted they can mess up if you go by them. They could have used the ae92 distributer, as the ae86 also has the sparkplugs go in the same style as the ae92 bigport where rens small port has a cover.
1989 Toyota Corolla GTS FWD LOW MILES!!!! Top1usa Vehicles 0 11-10-2005 12:38 AM
1989 corolla gts for sale!!!!! dlau420 Vehicles 19 06-22-2004 01:10 PM
Tuner Transformation needs a 85-87 Toyota Corolla GTS TunerTransforma General Discussion 17 05-19-2004 10:45 PM
FS: 1989 Corolla GTS AE92 ah_long Vehicles 15 04-23-2004 07:25 PM
