Help removing head unit in 97 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2006, 06:09 PM   #1 (permalink)
View RollaRolla's Photo Gallery
I'm trying to replace the head unit, and being the huge noob that I am, I can't even get the current one out. I removed the two screws on the bottom of the trimpanel, removed all the climate control knobs... and from my understanding, the panel should now just pull out with some prying. Well I've had no luck. It won't budge.
Any help would be greatly appreciated!
RollaRolla is offline   Reply With Quote
Old 08-15-2006, 06:45 PM   #2 (permalink)
View karazy's Photo Gallery
Prying just marks it up. You just have to give it a good hard jerk and it will pop out.
karazy is offline   Reply With Quote
Old 08-15-2006, 09:20 PM   #3 (permalink)
View jon_570's Photo Gallery
yes..actually..i started at one corner at the bottom and slowly pulled on it and it came out..dont give it one hard jerk..i have the same car as u.....slow and steady wins the race..
jon_570 is offline   Reply With Quote
Old 08-15-2006, 09:52 PM   #4 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
On my 93 prizm, it just pops off, there are 4 screws holding the head unit in place, remove those, unplug antenna wire, disconnect the plug in harness and remove.
Please get a trim kit and a harness plug in connector. So many people hack up the harness for no reason.
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
TheOtherCarolla is offline   Reply With Quote
Old 08-16-2006, 03:37 AM   #5 (permalink)
View TheSummoner101's Photo Gallery
don't worry, i had trouble my first time too...it's rather easy once u get the hang of it...just the first time is a tough one...don't jerk it, even tho it's hard to brake that one (since it's a lot of hard peices, much harder than some of the flimsy ones i've worked on) but yea start at lower right or left corner, and just push that dash part to the side and there are 4 push in prong thingis that u gotta pull out, stick ur hand under neat where the cassette holder thing is, and work ur way up...should work.
TheSummoner101 is offline   Reply With Quote
Old 08-16-2006, 07:47 AM   #6 (permalink)
also..make sure u unplug your a/c button..youre rear window defrost.. and your hazards
Old 08-16-2006, 08:00 PM   #7 (permalink)
Thank you all for the help, I got the unit out! Now I'm trying to put a new one in... and I've run into a snag. My old unit had a large black plug attached (it has many little metal pins on it) that my new unit has no spot for. So my only option is to leave this cord hang loose? Does anyone know what it does? Thanks again!
Old 08-16-2006, 08:22 PM   #8 (permalink)
Nevermind I figured it out. Thanks again! This forum rocks.
head unit problem...please help 80toy Audio, Video, and Security - Tech 7 08-01-2005 06:42 PM
removing head unit jeep2tacoma 2nd Generation (2005+) 1 05-10-2005 09:40 PM
Pioneer Head Unit Installation Question CamryMax Audio, Video, and Security - Tech 9 05-31-2003 01:00 PM
