ign coil problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2006, 07:44 PM   #1 (permalink)
gts-rated
xrated3345's Avatar
View xrated3345's Photo Gallery
AE92 ign coil problem
ok just finished my tune up. and drove home the wire on the ign coil sliped off. car just died. you know how when you put wires on a dis cap you feel and hear a snap. is the coil supose to have one? it slides right off if i twist it a certian way it kinda wants to stay. anyone help pls.
http://www.myspace.com/13833694
xrated3345 is offline   Reply With Quote
Old 08-15-2006, 09:16 PM   #2 (permalink)
gts-rated
xrated3345's Avatar
cmon somebody please.
Old 08-15-2006, 09:35 PM   #3 (permalink)
View toyomoho's Photo Gallery
Can’t say for this car. Some coils and coil wires have a plug/socket system that can only be inserted one way. If so, then the plug should snap into place. Look closely at the distributor cap terminals for a notch. The side of wire end plug should slide over this notch and lock. Look at the other plugs wires to see how the system is supposed to work. See if the end terminal plug on the distributor wire is broken.
1999 2WD Tacoma Coil Spring Compressor bill70 Hardcore Tech and Competition 2 09-23-2005 03:02 PM
odd vibration problem niju321 Camry & Solara Lounge 3 07-07-2005 12:15 PM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
MSD ignition coil - safe for MR2? StuckInNeutral MR2 Forum 10 10-12-2004 09:08 PM
ATTENTION!! 94-95 5sfe ign coil condentor failing....replace them profuse007 3rd & 4th Generation (1992–1996 & 1997–2001) 0 02-01-2004 06:12 PM
