Find the coolant drain plugs/valves for the radiator and engine block. Determine if the engine coolant system needs bleeding after replacing the coolant.
Drain the coolant from radiator, engine and coolant overflow tank. Caution, the coolant is toxic to people and animals so dispose of properly.
Remove the thermostat, disconnect the radiator top hose. Back flush the engine and radiator with water from a water hose until it come out clean. Drain the system again. Clean the overflow tank of any built up debris. Inspect the inside of the hoses for damage, signs of cracking, etc plus thermostat. Reinstall the thermostat in the exact same position as when removed. There may be an air bleed hole on its housing that needs to positioned properly. If you need to replace the gaskets for the housing, get them before doing the job. Or keep some type of gasket seal on hand. Reconnect all hoses, etc.
Fill the coolant system and overflow tank (to correct level at cold) with the proper mix of coolant and water, usually 50/50. To prevent corrosion use distilled water.
Start engine. As it warms up add more coolant mix as required. Once full, replace cap. Drive car normally. After parking car, let cool then check coolant levels again in radiator an overflow tank.
