oil gone somewhere.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2006, 09:25 AM   #1 (permalink)
View vetaldj's Photo Gallery
USA oil gone somewhere..
Hello,
I have Corolla 2000 with 104K. Month ago it started to use a lot of oil - I need to add about 4 qt after 3 weeks... There're no any leaks, there's no any smog... I replaced PCV Valve but looks like it didn't help... I was in the shop, they added some dye to oil, but when I returned they didn't find neither oil or dye... What else should I check or replace?
Sincerely
vetaldj is offline   Reply With Quote
Old 08-16-2006, 11:37 AM   #2 (permalink)
View jon_570's Photo Gallery
the same thing is happening to me but i have a 1997..we had a shop put dye in it and they didnt find any leaks..i have 137kmiles
jon_570 is offline   Reply With Quote
Old 08-16-2006, 11:55 AM   #3 (permalink)
It looks like very common problem for Corollas after 100K.... I know a lot of guys with the same issue and only two of them reported that it was fixed (1 - after PCV Valve was replace; 2 - dealer rebuild the engine that was under warranty...). Do anybody know what to do?
Old 08-16-2006, 12:23 PM   #4 (permalink)
View tashirosgt's Photo Gallery
Can you detect any sludge inside the head? What weight oil are you using?
tashirosgt is offline   Reply With Quote
Old 08-16-2006, 12:25 PM   #5 (permalink)
im using 10w-30
Old 08-16-2006, 01:12 PM   #6 (permalink)
I think the definitive way to diagnose sludge is to remove the valve cover and see if there is any jelling of the oil. Sludge is a controversial topic variously blamed on the oil, Toyota Motor Co or user maintenance. There are discussions of it at corollaland.com.
Unless you actually have emissions data, don't be sure your aren't burning oil. You can burn a lot of oil and not see a visible cloud.
Old 08-26-2006, 11:43 PM   #7 (permalink)
I have update....
I think that my problrm was resolved I change PCV Valve and the oil stands where it should be and in normal level. So, if you have same issue - the first thing that you should do - check you PCV Valve.
Old 08-27-2006, 01:44 AM   #8 (permalink)
View phil's Photo Gallery
what's a pcv valve & what does it do? are they expensive?
phil is offline   Reply With Quote
Old 08-27-2006, 08:58 PM   #9 (permalink)
View 94_Rolla_Guy's Photo Gallery
PCV=positive crankcase ventilation, what it does is use manifold vaccuum to clean out the dirty air and keep the crankcase from pressurizing itself, because upon presure being there the pressure pushes oil past the piston rings and valve seals creating a problem, its a cheap part (under $10) and is super easy to change!
jon_570 for you id bet $1000 its your oil control rings especially if its a 7A-FE (1.8L) as its a common problem with those engines!
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 08-27-2006, 09:12 PM   #10 (permalink)
View TRDwasiq's Photo Gallery
man same thing with my 1995 corolla burning oil i think its happening cuz i am redlining it too much almost everytime
TRDwasiq is offline   Reply With Quote
Old 08-28-2006, 09:18 PM   #11 (permalink)
View Cabanon's Photo Gallery
could it be the reason why im burning 1gallon of oil every month hahs....
im pissed off
'93 AE102 LE 1.8 5spd
'77 TE31 Deluxe 2TC 3spd Auto
Cabanon is offline   Reply With Quote
oil change interval question nomad 2nd Generation (2005+) 15 06-29-2010 10:01 PM
1MZFE engine sludge issue-help okanetoys General Discussion 9 08-06-2006 02:16 AM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 01:36 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 11:48 AM
Help!! Oil Puddle Under Engine Structureboy Camry & Solara Lounge 12 01-17-2003 01:04 PM
