weird knocking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2006, 11:42 AM   #1 (permalink)
View jon_570's Photo Gallery
USA weird knocking
i have a 1997 toyota corolla CE with 137k miles on it...about a year ago it started knocking when under acceleration..i switched to 10w-30 instead of 5w-30 thinking the thicker weight would stop it..it kinda helped..i was running 87octane gas then..i thn switched to 89 ctance and it stopp almost completely..here my question..my car runs great..idels perfect goes through the gears with no trouble..but when i shut it off it makes this weird knocking sound..lets just say i pull into wal-mart and i open the door and i turn the key back..like half a second later theres a weird either knocking or vibrating kinda sound coming out from the engine..only when u shut it off though..starts up fine..what could this be..ive checked everything and everythings good and secure...what could it be..Thanks
Jon
jon_570 is offline   Reply With Quote
Old 08-16-2006, 11:57 PM   #2 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
It sounds like what you are describing is whats called 'Dieseling' Where the engine acts like a diesel and takes a bit to shut off. Have you checked the timing of the engine, plugs and wires?
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 08-17-2006, 02:01 AM   #3 (permalink)
View toyomoho's Photo Gallery
Is the idle speed too high? In theory the engine cannot diesel without a fuel source. Are your injectors leaking when the ignition switch is off?
Old 08-17-2006, 04:30 PM   #4 (permalink)
idles at about 1000
Old 08-18-2006, 01:13 AM   #5 (permalink)
View 94_Rolla_Guy's Photo Gallery
its definately idleing fast it can't really after run or diesel because the injectors shut down killing fuel....
try cleaning the throtle body do a good job take it off the car and disassemble it, clean the IAC valve on the bottom under whiteish box with electrical connection that will most likely fix the idle. also check the A/C idle up valve (two hoses and electrical mounted on firewall behind intake) as they tend to get stuck
Id check your timing it doesn't take much extra timing to make it knock. Also you may have carbon build up something like a seafoam treatment might help..
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 08-18-2006, 09:20 AM   #6 (permalink)
whats the SEAFOAM treatment????
94 5sfe KNOCKING, WEIRD PROBLEM profuse007 3rd & 4th Generation (1992–1996 & 1997–2001) 7 08-11-2006 10:49 PM
knocking in my engine djfetus Camry & Solara Lounge 10 03-30-2006 07:17 PM
Strange Knocking... WreckedCamry Camry & Solara Lounge 15 01-24-2006 09:40 PM
Replaced front struts - but still get some knocking - Taken pics for comment 93auscamry Camry & Solara Lounge 0 06-21-2005 01:58 AM
