2ZZ Transmission Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2006, 05:30 PM   #1 (permalink)
jupiterboy's Avatar
View jupiterboy's Photo Gallery
He everyone! First post.
I have an XRS with just over 15,000 miles on it. Recently the transmission has been making a grinding sound when the car is hot. It is most evident in deceleration from 4000 rpms down. Fist is very loud, probably because of having less tire/road noise. The noise vanishes as you depress the clutch.
Anyone have a similar situation? Is this normal? The dealer has replaced a series of bearing in the trans. and I have a new clutch and flywheel at this point. No change in the noise.
Help!
jupiterboy is offline   Reply With Quote
Old 08-16-2006, 07:37 PM   #2 (permalink)
Whine connoisseur
View adsaba1969's Photo Gallery
does it sound like beebies in a tin can?
adsaba1969 is offline   Reply With Quote
Old 08-16-2006, 08:49 PM   #3 (permalink)
jupiterboy's Avatar
In a way, but more like normal transmission noise.
You think I have a detonation issue on top of a noisy trans? I'm entertaining any ideas at this point.
Don't I know you from somewhere?
Old 08-16-2006, 09:36 PM   #4 (permalink)
Whine connoisseur
your details are somewhat vague, I'm just curious as to why you're sure that it's the transmission. And the beebies in a can noise isn't necessarily detonation.
know me??....no, I doubt it
Old 08-16-2006, 09:56 PM   #5 (permalink)
jupiterboy's Avatar
The car in your sig belongs to a poster "adman" on 9thgen. I assumed you were that person, but then you may have actually stolen someones sig.
I think it is the transmission because is sounds like the transmission. The noise stops when you push in the clutch. A Toyota Tech thought it was the transmission and replaced most of the internal transmission bearings. The clutch and flywheel have also been changed. The noise persists.
I've also had a local friend that is a Toyota tech listen while I had the car on a lift and he said the noise was coming from the transmission case.
So, I'm stumped and trolling for others that have similar problems while I wait on another guy with and XRS and similar problems to get a new "transaxle" to see if that solves the problem.
What's your big idea?
Transmission Pinion Bearing noise zotparkerm Camry & Solara Lounge 3 09-26-2005 02:00 PM
2005 Corolla LE Transmission Noise prophase Archived Corolla threads 11 07-16-2005 10:45 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 02:19 AM
Transmission noise? James100 Camry & Solara Lounge 2 10-03-2004 12:40 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 11:06 AM
