I know ill have to get it re-mapped once i put in the injectors.
good luck doing that with the stock ecu.. time for a standalone!
my problem is now if the 135hp is even close
Trust me, its not. You wont get 135hp out of a 4A-FE with an intake and exhaust. and the TB, with those mods, why did you bother swapping it? I'm running forced induction with the stock TB of a 4A-FE.
if i want around 220hp (wont happen but with turbo ill try) ill need about 350cc injectors but i cant find any. i can find 450cc injectors though but with the pump running at 40psi i will need a regulater.
You'll need a regulator anyhow. I dont think the stock regulator will flow enough, plus I dont think it works with positive manifold pressure.
You can do dual injectors, or you can just get the 450CC injectors and drop the injector duty cycle to have them spray less.
