99 corolla. Timing belt or a timing chain? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2006, 11:36 PM   #1 (permalink)
View snguy82's Photo Gallery
Hi there,
Im asking this question for someone. This person brought his 99 corolla to do the timing belt and was told that it has a timing chain and does not require service. Is this true? If it is, this is pretty impressive.
thank you
snguy82 is offline   Reply With Quote
Old 08-18-2006, 12:31 AM   #2 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
on the 1ZZFE motors (which I am assuming this one is) will have the timing chain, and no service as far as I am ware of is scheduled for the chain....
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 08-18-2006, 12:55 AM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
chains have been around for years, I believe most domestics run chains. What they usually say about them is.. if they break replace it, as you can't really tell when they'll break.
Old 08-18-2006, 03:15 AM   #4 (permalink)
D
Is this the standard motor on the Corolla VE model?
thank you for your reply
Old 08-18-2006, 03:22 AM   #5 (permalink)
519
Custom User Title
519's Avatar
View 519's Photo Gallery
yep. the 1zz-fe is in all corollas 98-00
'99 Corolla VE
*If you're having car problems, I feel bad for you son...*
*I got 99 Problems but my toy ain't one.*
519 is offline   Reply With Quote
Old 08-18-2006, 01:40 PM   #6 (permalink)
thank you very much for your reply. Im very impressed that the corolla had the timing chain at this time. Certainly takes the hassle out of worrying about service or the belt snapping on ya.
cheers!
Old 08-18-2006, 02:44 PM   #7 (permalink)
View cheesep's Photo Gallery
It's definitely a timing chain. Check out the following link to learn more about your 1ZZ-FE engine.
http://spyderchat.com/1zzfe.pdf
cheesep is offline   Reply With Quote
Old 08-18-2006, 03:40 PM   #8 (permalink)
Jaspher's Avatar
View Jaspher's Photo Gallery
Early 1998 Corollas have 7A-FE engine. But halfway towards the production year they decided to go with 1ZZ-FE. Just check your engine code. There's should be a label on the hood that will either say 7A-FE or 1ZZ-FE.
2006 Silver ZZE-130
Jaspher is offline   Reply With Quote
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 03:59 AM
3VZ-FE... Timing belt or chain? AMScamrySE Camry & Solara Lounge 1 12-05-2004 01:46 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
Does the 2003 Tacoma v6 have a timing chain or belt? Markmmg 1st Generation (1995.5–2004) 2 07-12-2003 02:53 PM
99 Corolla Drive Belt Noise bedrock4x Archived Corolla threads 2 04-08-2002 05:45 PM
