metal scraping noise when turning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2006, 06:20 PM   #1 (permalink)
View ninjoe8's Photo Gallery
i am an owner of a 1995 manual toyota corolla. i don't know much about cars so this is probably my best bet at finding the solution to my problem.
about a week ago my car started to make a metal scraping noise whenever i was making a 90 degree right turn. When i let go of the steering wheel to even out, my car will drift slightly to the right. The only way to even out the car again is to make a 90 degree left turn, where i will here a slight scrape and my car will alighn itself correctly again.
Alternatively, when i make a 90 degree left turn, my car will drift to the left and i have to repeat the procedure above to even it out again.
What is causing this metal scraping/popping noise, which i believe is coming from the front right wheel of my car? I don't even have to be driving for the noise to come out. I can have the car in idle and turn the wheel all the way to the right and hear the same grinding noise.
Any help with this would be greatly appreciated.
ninjoe8 is offline   Reply With Quote
Old 08-18-2006, 11:22 PM   #2 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
My sisters car was doing that, but it wasnt a corolla it was a POS Chevy, and it turned out to be bad bushing on the front wheels, dunno if that is the same for the corolla tho.
d
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Scraping noise when applying brakes bigblueyota89 89-95 Toyota Pickup/Hilux 4 06-06-2006 08:05 PM
91 Tercel. Can anyone help me diagnose a noise I am having...axels/wheel balance? TercelLady Tercel, Paseo, Starlet, and Sera Forum 34 09-20-2005 10:29 AM
grinding noise when turning wuwho999 Camry & Solara Lounge 1 11-03-2004 10:00 PM
Worsening Noise In Engine lloydjv Celica Forum 2 02-09-2004 06:36 PM
88 Camry making horrible metal to metal engine noise Danielson 1st & 2nd Generation (1983–1986 & 1987-1991) 2 10-05-2001 03:07 PM
