95 cold air intake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2006, 06:29 PM   #1 (permalink)
View TRDwasiq's Photo Gallery
XXX 95 cold air intake
i just made a custom cold air intake for my 1995 corolla
2 question wht if ait sensor is not connected and during rainy season wht should i do
TRDwasiq is offline   Reply With Quote
Old 08-23-2006, 01:21 AM   #2 (permalink)
View RogueSeo's Photo Gallery
[IMG]file:///C:/Documents%20and%20Settings/WASIQ/Desktop/DSCI0005.JPG[/IMG]
link doesnt work.
RogueSeo is offline   Reply With Quote
Old 08-23-2006, 01:31 AM   #3 (permalink)
View toyomoho's Photo Gallery
Cannot see your photo, but. If the sensor is unplugged, you might get a check engine light. If you leave it connected and not inside the intake system. It might read hotter then the intake air temp and affect the fuel mixture. Try to install the sensor somewhere in your intake system. You could shield the sensor with something to protect it from water, just make sure the intake air is able to circulate around it.
Old 08-23-2006, 01:45 PM   #4 (permalink)
yea man my sensor is connected but its not connected to intake system though how much does it effect
Old 08-23-2006, 06:53 PM   #5 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
well it needs to read something in the intake. Mine had a vacum line fitting on the side of the pipe. I took some 3/8 heater hose, clamped it in there and plug the sensor in there. Runs find.
Mine ran the same without it in there. But if it came from the factory that why, why change it?
Also what you can do, is find a drill bit the same size as your sensor, take the gromet off your stock box, put it in the intake tract. Plug the sensor in. Btw, I would look into getting a heat shield for that filter. The area around the trans gets HOT. Mine is mounted right on top of the bottom gaurd with a heat shield, it makes a difference.
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
TheOtherCarolla is offline   Reply With Quote
Old 08-24-2006, 01:38 AM   #6 (permalink)
did you make that cai from the piece it yourself intake components being sold at pep boys and auto zone? if so thats nice.
Old 08-24-2006, 02:48 AM   #7 (permalink)
Can’t say how much it effects the engine operation. Hotter air is less dense; the ECU will adjust fuel system to compensate. Remember the engine compartment gets pretty hot.
Old 08-25-2006, 04:20 PM   #8 (permalink)
TN's bilingual ambassador
View Gerson's Photo Gallery
You know obx makes true CAI for 93-97 corolla/prism models. I may be getting one soon.
92 ウィンダム (ES300) VCV10L-BTMGKA 3.0L 3VZ-FE w/E53 5 speed
http://www.cardomain.com/ride/3302985
Gerson is offline   Reply With Quote
Old 09-01-2006, 03:02 AM   #9 (permalink)
post a pic/link?
cold air intake?????? 83yotanut Celica Forum 1 09-28-2004 09:35 PM
cold air intake ProjectCorolla Hardcore Tech and Competition 3 09-14-2004 04:46 AM
Question about AEM Cold Air Intake OCAMDDEAD Camry & Solara Lounge 3 09-11-2004 02:58 PM
Do It yourself Gen2 Cold Air Intake............IT WORKS!!!! the_beast 1st & 2nd Generation (1983–1986 & 1987-1991) 2 03-13-2004 01:53 AM
