Codes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2006, 01:44 AM   #1 (permalink)
View RogueSeo's Photo Gallery
Codes
im getting a solid abs light and air bag light going at start up and when im driving my 93 geo prizm. i have the 4afe motor in it. i took it to autozone, but they cant read obd I codes. anyone got any ideas whats wrong? car runs fine and i have no problems that i can speak of.
RogueSeo is offline   Reply With Quote
Old 08-23-2006, 03:33 AM   #2 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Air bag at startup is just a test light. It will stay on for 3sec or so. If it stays on or flashes - there is a problem with the Airbag system that you (unfortunately) will need to take to the stealership to fix.
As for the solid ABS light - it could be that one of the sensors has gone, or that you are low on fluid. Could also be the ABS CU but lets not speak of that I suggest taking it to a mechanic or a brake shop who knows what they are doing when it comes to ABS. But a solid light means something is wrong in the system...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 08-24-2006, 01:39 AM   #3 (permalink)
it stays on all the time. ill see about a dealer check up unfortunately. tnx!
"Check engine light" error codes po446, po442, po440???? serabell xA Forum 10 04-12-2009 10:31 PM
Prius Codes, no start crxdan Prius Forum 4 02-10-2007 03:40 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Reading codes White89SR5 Archived Corolla threads 3 03-12-2006 08:22 AM
Rading ABS Codes from 95 Toyota Camry satexascamry 3rd & 4th Generation (1992–1996 & 1997–2001) 12 04-09-2005 10:05 PM
