gas tank bolt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2006, 03:59 PM   #1 (permalink)
View igorien2k's Photo Gallery
gas tank bolt
the nut that is welded to the inside of the body that holds the fuel tank strap in my 8th gen broke and is now spinning so i cant tighten or loosen the bolt. its located just in front of the fuel tank. I had to loosen it to install a rear swaybar. does anyone know if there is a way to reach that nut from the cabin so i can hold it down and tighten it?
igorien2k is offline   Reply With Quote
Old 08-23-2006, 04:22 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Might be under the rear seat padding.
Old 08-25-2006, 01:37 PM   #3 (permalink)
i found out there is no way to get to it, unless you remove some of the body becauseits in its own sealed compartment does anyone know how long the gas tank bolts are? or how big the nut is in there because i'm about to drill the body to get to the nut but i'm afraid i'll ruin it and the gas tank will fall out permanently
Can't fill gas tank? kayakjohn 1st Generation (1995.5–2004) 3 01-08-2006 01:33 PM
Excessive pressure in gas tank? speedyts49 Celica Forum 6 08-28-2005 07:45 PM
Gas tank not reading full on gauge with fillup.... Anne Camry & Solara Lounge 14 10-30-2004 10:06 AM
Air into Gas tank CamNub General Discussion 9 03-04-2004 02:32 AM
